Only runs on one core at a time when parallel processing
Old   July 15, 2016, 16:42
Default Only runs on one core at a time when parallel processing
Tom Carr
Tnsguy is on a distinguished road
I have tried to run OF 1606+ on a windows machine with a Xenon E5-2687W processor in parallel processing mode. I have run the cyclone example and the test case described here:
http://www.pugetsystems.com/labs/hpc...d-Opteron-587/
Everything works as it should - directories are created for each core called out in decomposeParaDict and output is stored at each time step. However, the performance monitor in Task Manager shows only one core being used at a time. I am using a command like:
mpiexec -np 4 icoFoam -parallel
to initiate the run. What might be going on?
Thanks
Tnsguy is offline   Reply With Quote
Old   July 19, 2016, 17:59
Default Problem solved - Issue with VirtualBox
Tom Carr
It turns out that there is a setting in VirtualBox that defines the maximum number of processors it uses. When I increased this to 8, I was able to simulate using all 8 cores.
mpirun, multi-core, parallel computing
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 00:01
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 02:34
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
interDyMFoam in parallel idefix OpenFOAM Running, Solving & CFD 0 May 21, 2013 02:34
