Only runs on one core at a time when parallel processing |
July 15, 2016, 16:42 |
Tom Carr
I have tried to run OF 1606+ on a windows machine with a Xenon E5-2687W processor in parallel processing mode. I have run the cyclone example and the test case described here:
http://www.pugetsystems.com/labs/hpc...d-Opteron-587/ Everything works as it should - directories are created for each core called out in decomposeParaDict and output is stored at each time step. However, the performance monitor in Task Manager shows only one core being used at a time. I am using a command like: mpiexec -np 4 icoFoam -parallel to initiate the run. What might be going on? Thanks |
July 19, 2016, 17:59 |
Problem solved - Issue with VirtualBox
Tom Carr
It turns out that there is a setting in VirtualBox that defines the maximum number of processors it uses. When I increased this to 8, I was able to simulate using all 8 cores.
mpirun, multi-core, parallel computing |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
AMI interDyMFoam for mixer nu problem | danny123 | OpenFOAM Programming & Development | 8 | September 6, 2013 02:34 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
interDyMFoam in parallel | idefix | OpenFOAM Running, Solving & CFD | 0 | May 21, 2013 02:34 |
