August 1, 2016, 10:24 |
Residual control
Felix
Rep Power: 10 |
Well i have a case, in which i will reduce the runtime.
I am using the interPhasechangeDyM Solver I allredy have reduced the runtime from 100% to 33% with improving the pressure iteration speed. My Problem is that im iteration the variable p_corr. In that case I am using these specs below Code:
"pcorr.*" { solver GAMG; tolerance 1e-4; relTol 0; smoother DICGaussSeidel; cacheAgglomeration no; nCellsInCoarsestLevel 20; agglomerator faceAreaPair; mergeLevels 1; } ... PIMPLE { momentumPredictor no; correctPhi yes; nOuterCorrectors 7; nCorrectors 1; nNonOrthogonalCorrectors 10; residualControl { p_rgh { tolerance 1e-7; relTol 0; absTol 0; } } } Code:
Execution time for mesh.update() = 2.69 s GAMG: Solving for pcorr, Initial residual = 1, Final residual = 7.030918589e-05, No Iterations 15 GAMG: Solving for pcorr, Initial residual = 0.1618379063, Final residual = 9.09515451e-05, No Iterations 5 GAMG: Solving for pcorr, Initial residual = 0.03177132081, Final residual = 3.050995536e-05, No Iterations 5 GAMG: Solving for pcorr, Initial residual = 0.01138752385, Final residual = 5.915332199e-05, No Iterations 3 GAMG: Solving for pcorr, Initial residual = 0.004623339973, Final residual = 4.032533298e-05, No Iterations 3 GAMG: Solving for pcorr, Initial residual = 0.002091591789, Final residual = 2.678131328e-05, No Iterations 2 GAMG: Solving for pcorr, Initial residual = 0.000935694126, Final residual = 6.876109491e-05, No Iterations 1 GAMG: Solving for pcorr, Initial residual = 0.0004440894954, Final residual = 3.892454402e-05, No Iterations 1 GAMG: Solving for pcorr, Initial residual = 0.0002179582446, Final residual = 2.564707496e-05, No Iterations 1 GAMG: Solving for pcorr, Initial residual = 0.0001126573963, Final residual = 1.363380582e-05, No Iterations 1 GAMG: Solving for pcorr, Initial residual = 5.807458978e-05, Final residual = 5.807458978e-05, No Iterations 0 time step continuity errors : sum local = 3.835607192e-09, global = 8.465794602e-12, cumulative = 8.465794602e-12 Code:
Execution time for mesh.update() = 2.72 s GAMG: Solving for pcorr, Initial residual = 1, Final residual = 9.089048299e-05, No Iterations 28 GAMG: Solving for pcorr, Initial residual = 0.0002686212536, Final residual = 4.119209357e-05, No Iterations 1 GAMG: Solving for pcorr, Initial residual = 7.742703334e-05, Final residual = 7.742703334e-05, No Iterations 0 GAMG: Solving for pcorr, Initial residual = 7.742703334e-05, Final residual = 7.742703334e-05, No Iterations 0 GAMG: Solving for pcorr, Initial residual = 7.742703334e-05, Final residual = 7.742703334e-05, No Iterations 0 GAMG: Solving for pcorr, Initial residual = 7.742703334e-05, Final residual = 7.742703334e-05, No Iterations 0 GAMG: Solving for pcorr, Initial residual = 7.742703334e-05, Final residual = 7.742703334e-05, No Iterations 0 GAMG: Solving for pcorr, Initial residual = 7.742703334e-05, Final residual = 7.742703334e-05, No Iterations 0 GAMG: Solving for pcorr, Initial residual = 7.742703334e-05, Final residual = 7.742703334e-05, No Iterations 0 GAMG: Solving for pcorr, Initial residual = 7.742703334e-05, Final residual = 7.742703334e-05, No Iterations 0 GAMG: Solving for pcorr, Initial residual = 7.742703334e-05, Final residual = 7.742703334e-05, No Iterations 0 time step continuity errors : sum local = 1.8005001e-05, global = 4.661703486e-06, cumulative = 4.661711952e-06 |
August 2, 2016, 08:04 |
Felix
Rep Power: 10 |
What i exactly mean is the following:
is there any residual criteria for the nNonOrthogonalCorrectors? I dont wanna do additional iterations loops, when the nNonOrthogonalCorrectors allready have reached the residuals. |
fvsolutions, gamg, iterations, pimple, p_corr |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
