Help: Strange unphysical results from mesh motion |
August 17, 2016, 12:29 |
Dear All,
Does anyone have any ideas why the water surface is following the deformation in the mesh rather than recalculating and following the physically correct water surface level? I've attached the fvSchemes and fvSolutions. Any hints on what may be wrong would be much appreciated! fvScheme: Code:
ddtSchemes { default Euler; // default CrankNicolson 0.9; } gradSchemes { default Gauss linear; } divSchemes { div(rhoPhi,U) Gauss limitedLinearV 1; div(phi,alpha) Gauss vanLeer; div(phirb,alpha) Gauss interfaceCompression; div(phi,k) Gauss upwind; div(phi,epsilon) Gauss upwind; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p_rgh; pcorr; alpha.water; } // ************************************************************************* // Code:
solvers { "alpha.water.*" { nAlphaCorr 2; nAlphaSubCycles 3; cAlpha 1.0 icAlpha 0; MULESCorr yes; nLimiterIter 8; alphaApplyPrevCorr true; solver smoothSolver; smoother symGaussSeidel; tolerance 1e-8; relTol 0; } "pcorr.*" { solver PCG; preconditioner { preconditioner GAMG; tolerance 1e-7; relTol 0; smoother DICGaussSeidel; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } tolerance 1e-7; relTol 0; maxIter 100; } p_rgh { solver GAMG; tolerance 1e-7; relTol 0.05; smoother DIC; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } p_rghFinal { solver PCG; preconditioner { preconditioner GAMG; tolerance 1e-8; relTol 0; smoother DICGaussSeidel; nPreSweeps 2; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } tolerance 1e-8; relTol 0; maxIter 20; } "(U|k|epsilon)" { solver PBiCG; preconditioner DILU; smoother GaussSeidel; tolerance 1e-06; relTol 0.1; nSweeps 1; } "(U|k|epsilon)Final" { solver smoothSolver; smoother GaussSeidel; tolerance 1e-07; relTol 0; nSweeps 1; } } PIMPLE { momentumPredictor no; nCorrectors 3; nOuterCorrectors 150; nNonOrthogonalCorrectors 1; residualControl { U { tolerance 1e-5; relTol 0; } p_rgh { tolerance 5e-4; relTol 0; } } correctPhi yes; moveMeshOuterCorrectors yes; } relaxationFactors { fields { p_rgh 0.7; p_rghFinal 1; // 0.3 ~ 22 iterations } equations { "U|k|epsilon" 0.3; "(U|k|epsilon)Final" 1; } } // ************************************************************************* // |
meshmotion, wavedymfoam |
CFX FSI Fatal Error | unbanana | CFX | 0 | October 3, 2015 05:57 |
Update of the variables after dynamic mesh motion. | gtg258f | OpenFOAM Programming & Development | 9 | January 18, 2014 10:08 |
Ansys mesh for FLUENT software giving unrealistic results, while GAMBIT mesh is fine | kbhamidipa3 | FLUENT | 0 | November 30, 2012 15:52 |
Different zone motion and mesh motion preview | aamer | FLUENT | 5 | September 24, 2012 13:58 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
