solidBodyMotionFunction for a decelerating object
Old   September 12, 2016, 08:35
Default solidBodyMotionFunction for a decelerating object
ShinyRiver's Avatar
Roozbeh
ShinyRiver is on a distinguished road
Dear All,
I have recently installed foam-extent 3.2 and tried with the "moving cylinder" tutorial successfully. I use "translation" as the "solidBodyMotionFunction".
QUESTION:
If I want to have a time-dependent velocity of the immeresed body, let say acceleration or deceleration, how I can set it? I know if I want to have ACCELERATION from zero to the fixed value of the velocity in a certain time, I can set the "rampTime" equal to that time interval, right? But how I can set a decelerating movement?
Many thanks in advance,
ShinyRiver
ShinyRiver is offline   Reply With Quote
Old   September 14, 2016, 05:12
ShinyRiver's Avatar
Roozbeh
SKA (Sea keeping Analysis)
error in fireFoam, when running the case wallFireSpread2D zhoubiao1088 OpenFOAM Running, Solving & CFD 9 February 1, 2018 18:45
[foam-extend.org] Error compiling OpenFOAM-1.6-ext Canesin OpenFOAM Installation 137 January 20, 2016 14:56
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 04:55
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
