October 9, 2016, 04:37 |
how to map boundaries in openfoam?
Rep Power: 12 |
Hello everyone. I want to use chtMultiRegionSimpleFoam. However, I do not want to use mappedWall. In my case, I have wall boundaries instead of mappedWall.
I just want to copy temperature values on wall1 boundary of solid region to wall2 of fluid region and want to solve governing equations separately in each region. In other words, I just want to define mapping for temperature, nothing more. How can I do that? Is it possible to do in OpenFOAM or do I need to use swak4foam? How can I copy values using swak4foam? Every example I have seen online was for calculating expressions using swak4foam. Is it possible to just map the values from one boundary to another using swak4foam? |
January 31, 2017, 05:11 |
F
Rep Power: 9 |
Hey,
how did you solved it? I've got the same problem... |
How to Map Fields in openFOAM using the utility | Alhasan | OpenFOAM Running, Solving & CFD | 42 | January 15, 2018 08:52 |
OpenFOAM Training Beijing 22-26 Aug 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | May 3, 2016 04:57 |
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker | rt08 | OpenFOAM Installation | 1 | February 28, 2016 19:00 |
Map data from a big to a small domain in OpenFOAM | sagnikmazumdar | OpenFOAM | 1 | January 24, 2013 03:12 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 05:56 |
