Interfoam failed to solve for alpha (air-water flow in 3D pipe)
Like Tree4Likes
  • 1 Post By arsalan.dryi
  • 1 Post By Dipsomaniac
  • 1 Post By mizzou
Old   October 28, 2016, 04:11
Default Interfoam failed to solve for alpha (air-water flow in 3D pipe)
Milad
mizzou is on a distinguished road
Guys,
I am getting so confused. I used to simulate 2D air-water two phase flow using interFoam as the solver, but recently I just switched to 3D simulation. Unfortunately I just came up with no results for alpha (volume phase fraction).
I used blockMesh to create my geometry as below:
| \\ / O peration | Version: 2.4.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 0.01;
vertices
(0 0 0) //0
(0.3535 0.3535 0) //1
(-0.3535 0.3535 0) //2
(-0.3535 -0.3535 0) //3
(0.3535 -0.3535 0) //4
(0.3535 0.3535 30) //5
(-0.3535 0.3535 30) //6
(-0.3535 -0.3535 30) //7
(0.3535 -0.3535 30) //8
(0 0 30) //9
blocks
hex (1 2 3 4 5 6 7 8) (10 10 150) simpleGrading (1 1 1)
edges
arc 1 2 (0 0.5 0)
arc 2 3 (-0.5 0 0)
arc 3 4 (0 -0.5 0)
arc 4 1 (0.5 0 0)
arc 5 6 (0 0.5 30)
arc 6 7 (-0.5 0 30)
arc 7 8 (0 -0.5 30)
arc 8 5 (0.5 0 30)
boundary
inlet
type patch;
faces
(1 2 3 4)
outlet
type patch;
faces
(5 6 7 8)
fixedWalls
type wall;
faces
(5 6 2 1)
(6 7 3 2)
(7 8 4 3)
(8 5 1 4)
mergePatchPairs
I was actually wondering if I did not set the proper inlet condition for alpha!
FoamFile
version 2.0;
format ascii;
class volScalarField;
object alpha.water;
dimensions [0 0 0 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type inletOutlet;
inletValue uniform 0.5;
value uniform 0.5;
outlet
type zeroGradient;
fixedWalls
type zeroGradient;
But just take a look at the result of alpha for example @ t=0.1s:
| \\ / O peration | Version: 2.3.0 |
FoamFile
version 2.0;
format ascii;
location "0.1";
object alpha.water;
boundaryField
inlet
type inletOutlet;
value uniform 0;
outlet
type zeroGradient;
fixedWalls
type zeroGradient;
I appreciate if anyone could please make any comments on that.
mizzou is offline   Reply With Quote
Old   October 28, 2016, 04:46
Arsalan
arsalan.dryi is on a distinguished road
Hi Milad,
what did you set the inlet boundary condition for velocity? please give detailed information for a more accurate solution.
Furthermore, its better to use [CODE] tag for writing dictionaries in your thread, anyway it has a better representation.
Regards,
Arsalan.
mizzou likes this.
arsalan.dryi is offline   Reply With Quote
Old   October 28, 2016, 11:08
Milad
Originally Posted by arsalan.dryi View Post
Hi Milad,
Regards,
Arsalan.
Dear Arsalan
Thank you so much for your response. I used fixedVelocity for inlet U. Attached hereby, please find my case file.
Best,
Milad
Old   October 29, 2016, 04:20
Brian Willis
Dipsomaniac is on a distinguished road
Hi Milad
Check your U boundary condition in your 0 time directory. The length of your pipe is along the z-direction. Your U boundary condition on the inlet is (1 0 0). Changing it to (0 0 1) should sort out your problem. I tested it out and it works with just that change.
Regards,
Brian
mizzou likes this.
Dipsomaniac is offline   Reply With Quote
Old   October 29, 2016, 07:13
Arsalan
Hi Milad,
As Brian said, you should modify velocity boundary condition at inlet along the Z direction and normal to the patch (like (0,0,1)),this will solve the problem.
Regards,
Arsalan.
mizzou likes this.
Old   October 29, 2016, 07:41
Milad
Dear fiends Brian and Arsalan,
I really appreciate your helps. You are right and that worked.
Thank you!
Dipsomaniac likes this.
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
flow from water pipe leak to sand domain tangfl ANSYS 1 May 13, 2013 04:15
3D-Simulation of Water Flow From Nozzle into Air Navin Sampath FLOW-3D 2 February 26, 2009 10:46
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
