Flow regime for internal pipe flow
Old   November 3, 2016, 07:21
Default Flow regime for internal pipe flow
Sebastian Trunk
sisetrun is on a distinguished road
Hello Foamers,
I am not 100% sure how I should proceed with my simulations. My case/simulation setup looks as follows:
I have a "zeolite-like" (http://cdn4.explainthatstuff.com/zeo...-structure.jpg) 3d structure inside a tube. The structure itself consists of 10x10x20 cells, which look similar to those from the picture.
I would like to investigate the effect of superficial gas velocity on the flow field. (0.5 - 7m/s)
I think that for the slow velocities, the flow should be laminar. For the higher velocities it will turn to a turbulent flow.
So, the questions which I could not answer myself are:
1) How do I calculate a Re number? Should I calculate a particle Re number instead of the overall tube Re number for estimating y+?
2) When I start laminar (simpleFoam), how can I find out if my flow is in the transition to turbulent flow?
3) Should I use the kklomega model to scan through all the different velocities with the same case setup? Can I use simpleFoam for every velocity or pimpleFoam for the higher velocities?
Any help is highly appreciated...Thank you for your thoughts!
Best regards,
Sebastian
sisetrun is offline   Reply With Quote
internal flow, re number, turbulence and laminar
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) florian_krause OpenFOAM 22 June 13, 2013 21:25
[ASK] Flow in Corrugated Pipe with FLUENT Primadhani FLUENT 1 May 11, 2011 20:41
Pipe Flow Saima CFX 1 January 10, 2011 16:41
Turbulence in a pipe flow JM Main CFD Forum 4 December 21, 2006 04:04
