Problem with mpirun in ssh connection
Old   April 22, 2017, 06:29
Default Problem with mpirun in ssh connection
blttkgl is on a distinguished road
Hey,
I am not sure if cfd-online forums is the correct place to ask this question but here it goes.
I try to simulate my case with multiple cores using my faculties remote server, connecting from ssh protocol. When I decompose my case and try to run I get the following error:
mpirun -np 4 XiFoam -parallel
NVIDIA: no NVIDIA devices found
[force:26426] *** Process received signal ***
[force:26426] Signal: Bus error (7)
[force:26426] Signal code: Non-existant physical address (2)
[force:26426] Failing at address: 0x7fbc3ad85780
[force:26427] *** Process received signal ***
[force:26427] Signal: Bus error (7)
[force:26427] Signal code: Non-existant physical address (2)
[force:26427] Failing at address: 0x7f338d01fe50
[force:26428] *** Process received signal ***
[force:26428] Signal: Bus error (7)
[force:26428] Signal code: Non-existant physical address (2)
[force:26428] Failing at address: 0x7fd155806898
[force:26429] *** Process received signal ***
[force:26429] Signal: Bus error (7)
[force:26429] Signal code: Non-existant physical address (2)
[force:26429] Failing at address: 0x7fdcc8c5bd50
[force:26429] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7fdcd99e24b0]
[force:26429] [ 1] /usr/lib/openmpi/lib/openmpi/mca_btl_vader.so(mca_btl_vader_frag_init+0x8e)[0x7fdccb1e329e]
[force:26429] [ 2] /usr/lib/libmpi.so.12(ompi_free_list_grow+0x1a9)[0x7fdcd7544cf9]
[force:26429] [ 3] /usr/lib/openmpi/lib/openmpi/mca_btl_vader.so(+0x1ea4)[0x7fdccb1e0ea4]
[force:26429] [ 4] /usr/lib/openmpi/lib/openmpi/mca_bml_r2.so(+0x16b3)[0x7fdccb5ec6b3]
[force:26429] [ 5] /usr/lib/openmpi/lib/openmpi/mca_pml_ob1.so(mca_pml_ob1_add_procs+0xca)[0x7fdcca2dac1a]
[force:26429] [force:26426] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7fbc53bd54b0]
[force:26426] [ 1] /usr/lib/openmpi/lib/openmpi/mca_btl_sm.so(+0x4c4a)[0x7fbc44cecc4a]
[force:26426] [ 2] /usr/lib/libmpi.so.12(ompi_free_list_grow+0x189)[0x7fbc51737cd9]
[force:26426] [ 3] /usr/lib/openmpi/lib/openmpi/mca_btl_sm.so(mca_btl_sm_add_procs+0x689)[0x7fbc44cea9c9]
[force:26426] [ 4] /usr/lib/openmpi/lib/openmpi/mca_bml_r2.so(+0x16b3)[0x7fbc4572f6b3]
[force:26426] [ 5] /usr/lib/openmpi/lib/openmpi/mca_pml_ob1.so(mca_pml_ob1_add_procs+0xca)[0x7fbc4441dc1a]
[force:26426] [ 6] /usr/lib/libmpi.so.12(ompi_mpi_init+0x859)[0x7fbc51753109]
[force:26426] [ 7] /usr/lib/libmpi.so.12(MPI_Init+0x15d)[0x7fbc5177154d]
[force:26426] [ 8] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so(_ZN4Foam8UPstream4initERiRPPc+0x1f)[0x7fbc539964cf]
[force:26426] [ 9] [force:26427] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7f339de464b0]
[force:26427] [ 1] /usr/lib/openmpi/lib/openmpi/mca_btl_vader.so(mca_btl_vader_frag_init+0x8e)[0x7f338f58729e]
[force:26427] [ 2] /usr/lib/libmpi.so.12(ompi_free_list_grow+0x1a9)[0x7f339b9a8cf9]
[force:26427] [ 3] /usr/lib/openmpi/lib/openmpi/mca_btl_vader.so(+0x1ea4)[0x7f338f584ea4]
[force:26427] [ 4] /usr/lib/openmpi/lib/openmpi/mca_bml_r2.so(+0x16b3)[0x7f338f9906b3]
[force:26427] [ 5] /usr/lib/openmpi/lib/openmpi/mca_pml_ob1.so(mca_pml_ob1_add_procs+0xca)[0x7f338e67ec1a]
[force:26427] [ 6] [force:26428] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7fd16ee0d4b0]
[force:26428] [ 1] /usr/lib/openmpi/lib/openmpi/mca_allocator_bucket.so(mca_allocator_bucket_alloc _align+0x98)[0x7fd1615c80e8]
[force:26428] [ 2] /usr/lib/openmpi/lib/openmpi/mca_mpool_sm.so(mca_mpool_sm_alloc+0x28)[0x7fd160fbce58]
[force:26428] [ 3] /usr/lib/openmpi/lib/openmpi/mca_btl_sm.so(mca_btl_sm_add_procs+0x5d4)[0x7fd15ff6b914]
[force:26428] [ 4] /usr/lib/openmpi/lib/openmpi/mca_bml_r2.so(+0x16b3)[0x7fd1609b06b3]
[force:26428] [ 5] /usr/lib/openmpi/lib/openmpi/mca_pml_ob1.so(mca_pml_ob1_add_procs+0xca)[0x7fd15f69ec1a]
[force:26428] [ 6] /usr/lib/libmpi.so.12(ompi_mpi_init+0x859)[0x7fd16c98b109]
[force:26428] [ 7] /usr/lib/libmpi.so.12(MPI_Init+0x15d)[0x7fd16c9a954d]
[force:26428] [ 8] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so(_ZN4Foam8UPstream4initERiRPPc+0x1f)[0x7fd16ebce4cf]
[force:26428] [ 9] /usr/lib/libmpi.so.12(ompi_mpi_init+0x859)[0x7f339b9c4109]
[force:26427] [ 7] [ 6] /usr/lib/libmpi.so.12(ompi_mpi_init+0x859)[0x7fdcd7560109]
[force:26429] [ 7] /usr/lib/libmpi.so.12(MPI_Init+0x15d)[0x7fdcd757e54d]
[force:26429] [ 8] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so(_ZN4Foam8UPstream4initERiRPPc+0x1f)[0x7fdcd97a34cf]
[force:26429] [ 9] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7argListC1ERiRPPcbbb+0x47a)[0x7fdcdaad87ca]
[force:26429] [10] XiFoam[0x42ddff]
[force:26429] [11] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7fdcd99cd830]
[force:26429] [12] XiFoam[0x43d3b9]
[force:26429] *** End of error message ***
/usr/lib/libmpi.so.12(MPI_Init+0x15d)[0x7f339b9e254d]
[force:26427] [ 8] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so(_ZN4Foam8UPstream4initERiRPPc+0x1f)[0x7f339dc074cf]
[force:26427] [ 9] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7argListC1ERiRPPcbbb+0x47a)[0x7f339ef3c7ca]
[force:26427] [10] XiFoam[0x42ddff]
[force:26427] [11] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7f339de31830]
[force:26427] [12] XiFoam[0x43d3b9]
[force:26427] *** End of error message ***
/opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7argListC1ERiRPPcbbb+0x47a)[0x7fbc54ccb7ca]
[force:26426] [10] XiFoam[0x42ddff]
[force:26426] [11] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7fbc53bc0830]
[force:26426] [12] XiFoam[0x43d3b9]
[force:26426] *** End of error message ***
/opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7argListC1ERiRPPcbbb+0x47a)[0x7fd16ff037ca]
[force:26428] [10] XiFoam[0x42ddff]
[force:26428] [11] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7fd16edf8830]
[force:26428] [12] XiFoam[0x43d3b9]
[force:26428] *** End of error message ***
mpirun noticed that process rank 0 with PID 26426 on node force exited on signal 7 (Bus error).
mpirun works smoothly if i use the cores in my notebook but I will be running bigger cases and will need 10+ cores very soon.
Any idea or help is much appreciated!
Bulut
blttkgl is offline   Reply With Quote
OF mpirun and parallel problem heksel8i OpenFOAM Running, Solving & CFD 2 September 11, 2013 05:33
Parallel processing problem with Fluent Harish FLUENT 3 February 8, 2011 09:49
[OpenFOAM] Weird Problem with ParaFoam via SSH cwang5 ParaView 2 July 19, 2010 09:00
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
