request for RAS RASProperties error
Old   November 17, 2016, 11:59
Default request for RAS RASProperties error
FlyBob91's Avatar
FlyBob91 is on a distinguished road
Hello to all,
I made my own adjoint solver and now i'm trying to run my first case with it, but i have the following problem:
--> FOAM FATAL ERROR:
    request for RAS RASProperties from objectRegistry region0 failed
    available objects of type RAS are
0()
    From function const Type& Foam::objectRegistry::lookupObject(const Foam::word&) const [with Type = Foam::RASModel<Foam::IncompressibleTurbulenceModel<Foam::transportModel> >]
    in file /home/roby/OpenFOAM/OpenFOAM-4.1/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 193.
and i don't know why because i compiled correctly the solver.
I have to run a simple laminar simulation and i set my turbolenceProperties in this manner
simulationType laminar;
and i didn't change anything of the pitzdaily incompressible case.
I also linked the createFields.H and Main.C files of my solver
FlyBob91 is offline   Reply With Quote
Old   April 25, 2017, 02:34
le
fsifsi is on a distinguished road
I encounter same message. Did you solve it ?
Thanks
fsifsi is offline   Reply With Quote
Pressure outlet boundary condition rolando OpenFOAM Running, Solving & CFD 62 September 18, 2017 06:45
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 07:11
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 07:24
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
