usage of kinematicSingleLayer
Old   November 30, 2016, 08:26
Default usage of kinematicSingleLayer
fsch1 is on a distinguished road
i have some troubles using the kinematicSingleLayer.
The basis for my simulation is the hot-box tutorial. But I don't need the thermal results, just the wallFilm. For simplification I want to change the surfaceFilmModel from thermoSingleLayer to kinematicSingleLayer.
In the reactingCloud1Properties I still have this line:
    surfaceFilmModel thermoSurfaceFilm;
and in the surfaceFilmProperties i made this change:
surfaceFilmModel kinematicSingleLayer; // thermoSingleLayer;
regionName      wallFilmRegion;
active          true;
kinematicSingleLayerCoeffs
    filmThermoModel constant;
    constantCoeffs
        specie      water;
        rho0        1000;
        mu0         1e-3;
        sigma0      0.07;
the liquidCoeffs I copied from the rivulet-tutorial.
But now, when I run the reactingParcelFilmFoam I get
Constructing surface film model
Selecting surfaceFilmModel kinematicSingleLayer
    Selecting region model functions
    none
    Selecting filmThermoModel constant
    Selecting film injection models
        none
    Selecting filmTurbulenceModel laminar
    Selecting film force models
        contactAngle
Selecting distribution model normal
        thermocapillary
No finite volume options present
Courant Number mean: 0.003975948189 max: 0.01690175586
Starting time loop
Courant Number mean: 0.003975550634 max: 0.01690006585
Film max Courant number: 0
deltaT = 1.439677512e-05
Time = 1.43968e-05
Solving 3-D cloud reactingCloud1
--> FOAM FATAL ERROR:
Ts field not available for kinematicSingleLayer
    From function virtual const volScalarField& Foam::regionModels::surfaceFilmModels::kinematicSingleLayer::Ts() const
    in file kinematicSingleLayer/kinematicSingleLayer.C at line 1012.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::regionModels::surfaceFilmModels::kinematicSingleLayer::Ts() const at ??:?
#3  Foam::ThermoSurfaceFilm<Foam::KinematicCloud<Foam::Cloud<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > > > >::cacheFilmFields(int, int, Foam::regionModels::surfaceFilmModels::surfaceFilmModel const&) at ??:?
#4  ? at ??:?
#5  ? at ??:?
#6  ? at ??:?
#7  ? at ??:?
#8  ? at ??:?
#9  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#10  ? at ??:?
Abort
where do I have to define the Ts? As I understand, its the temperature on the surface of the wall.
fsch1 is offline   Reply With Quote
Decreasing the memory RAM usage of Fluent Rui_27 FLUENT 0 July 10, 2015 05:18
New workstation for different usage scenarios - CPU and RAM natem Hardware 6 August 7, 2013 02:47
Boosting CPU usage earlybird FLUENT 2 November 2, 2012 10:32
How to max the CPU usage? Christoph_84 Hardware 2 June 8, 2011 15:45
OpenFOAM Solver/BC usage description murrayjc OpenFOAM 3 August 25, 2009 04:48
