Slurry (sand water) flow in twoPhaseEulerFlow possible?
Like Tree5Likes
Old   October 24, 2011, 08:14
Smile Slurry (sand water) flow in twoPhaseEulerFlow possible?
Jochem van den Bosch
jochemvandenbosch is on a distinguished road
Hi everybody,
As a part of my MSc. thesis I am trying to model a slurry flow (sand/water) in OpenFOAM (for different geometries). I heard that i could best use the twoPhaseEulerFlow solver for this problem, however I have found only examples regarded pneumatic conveying in combination for this solver.
Can this solver also be used for a liquid/solid interface. Some specifics of my research are:
Turbulent flow (Re>>2300)
Pipe flow
Sand (2600kg/m^3), water mixture
Concentrations ranging from 10 to 40%
Medium fine sand, d50 approximately 300-600 micrometer
I am particularly interested in the pressure drop allong the length of the pipe. Is the twoPhaseEulerFlow the right solver to use and do you think I would have to adjust this solver. If it is not the one to use, which one should I use.
Thanks so much in advance!!!
Best regards!
ebtedaei and Jack_Kerouac like this.
jochemvandenbosch is offline   Reply With Quote
Old   October 26, 2011, 11:27
Alberto Passalacqua
Yes, it should work. The code might present some instability if particles pack. Please, search the forum for discussions on the topic.
Alberto Passalacqua
Old   October 27, 2011, 03:21
Hi Alberto. Thanks for your response. I did some research (mostly on this forum) and for now I've decided to go with settlingFoam instead of twoPhaseEulerFoam, since the first is based on the drift-flux model, which I already have some experience with (is taught by my university). Also packing might occur (not sure). settlingFoam seems more appropiate for this task (although it doesn't provide means to simulate a sliding bed...).
Do you know of any thesis' that use settlingFoam to simulate slurry flow.
Thanks in advance & best regards,
ebtedaei likes this.
Old   October 27, 2011, 14:26
Alberto Passalacqua
OK. Just keep in mind that the algebraic slip model (mixture model) is valid for relatively low particle concentrations and it might have limitations on the Stokes number.
BTW, I am working on slurry flow with my (heavily) modified version of twoPhaseEuler, and it is working fairly well.
Alberto Passalacqua
Old   October 31, 2011, 04:25
Hi Alberto, thanks for your tips. About the mixture model for low concentration, my professor (Cees van Rhee) used this model in het PhD thesis (on the sedimentation process in a trailing suction hopper dredger) succesfully for concentrations up to 40% (sand in water). What are your thoughts about this (what do you consider a high concentration?)?
Best regards,
ps. what kind of slurry flow are you working on, sand/water? And open-channel flow or pipeflow?
Old   October 31, 2011, 10:46
Alberto Passalacqua
Hi Jochem,
as long as the hypotheses behind the model are satisfied, you can use it. Remember that the mixture model is derived making quite strong assumptions:
- Local equilibrium among the phases, which limits the validity to low Stokes numbers
- Mixture hypothesis, which limits the property ratio of the phases
When it comes to fluid-particle flows, the mixture model is suggested in case the particle loading is "low". How low depends on the flow conditions, but since you do not consider particle-particle interactions, I would say ~10%. You find applications with much higher concentrations, however. There are doubts on the validity of the model under those conditions however.
I deal with slurry flow in ducts (high St number).
Best,
Alberto Passalacqua
Old   December 18, 2015, 07:09
Ali
ali.m.1 is on a distinguished road
Hi both,
In regards to the original question, is there an Euler-Euler solver available for particle/fluid flow? I'm using twoPhaseEulerFoam, but I don't like how I have to include temperature. The openFoam website says the model is incompressible, but it clearly isn't.
Any help is appreciated!
regards
ali.m.1 is offline   Reply With Quote
Old   December 25, 2015, 23:03
Alberto Passalacqua
This has been addressed in reactingTwoPhaseEulerFoam (OF 3.0.x or -dev from the Foundation). You can set phases to be isothermal, and the energy equation won't be solved.
The model can be compressible or incompressible, depending on how you set the thermodynamic properties of the phases (see fluidisedBed tutorial, where the solid phase is incompressible).
Alberto Passalacqua
Last edited by alberto; December 25, 2015 at 23:05. Reason: Added consideration on compressibility
Old   January 5, 2016, 08:58
Ali
Thanks for your reply Alberto. I'm using 2.3.x, so I’ll upgrade.
I'm planning on combining this solver with DPMFoam, have you heard of anything else like this? Combining two solvers I mean... For example solver A running in the top of the domain, and solver B running in the bottom of the domain. I think it will be tricky, but not impossible.
Your help is appreciated!
regards
Old   March 18, 2016, 11:27
rdbisme's Avatar
Ruben Di Battista
rdbisme is on a distinguished road
Dear @alberto,
How do I set the phases isothermal? I tried to set up the diameterModel as isothermal and minIter for the energy equation to 0 but it stills continue to solve energy for both phases.
rdbisme is offline   Reply With Quote
Old   March 24, 2016, 07:23
Ali
Ruben, see below:
http://www.cfd-online.com/Forums/ope...tml#post580432
Old   March 30, 2016, 05:27
rdbisme's Avatar
Ruben Di Battista
Originally Posted by ali.m.1 View Post
Thank you. I also managed to make it shutting down even with bare twoPhaseEulerFoam and reported it in the thread you're quoting. =)
Old   November 15, 2016, 21:27
Bryant
spf521 is on a distinguished road
Hi everyone,
I'm interested in the topic of particle/fluid flow. Now I want to simulate the dry particle (above water surface in the beginning) flows into water. Is it possible to use twoPhaseEulerFoam to simulate this phenominon? For this problem, I want to capture the free surface of particle flow and water flow, and ignore the effect of the air.
Thanks in advance!
BR
spf521 is offline   Reply With Quote
Old   November 16, 2016, 10:35
rdbisme's Avatar
Ruben Di Battista
Originally Posted by spf521 View Post
Hi everyone,
Thanks in advance!
BR
I believe that if you're interested to the free surface twoPhaseEulerFoam is not the right solver. I would choose using VOF (e.g. interFoam).
Old   November 16, 2016, 19:33
Bryant
Hi Ruben,
Thanks for your quick reply. VOF is indeed a good way for free-surface problem. But I want to simulate the interactions between particle and fluid, and use Kinetic theory to simulate interactions between particles. So I want to make some modifications based on interfoam or twoPhaseEulerFoam. Do you think which is easier to implement, 1) Adding KT part into interFoam or 2) Adding a free-surface capturing part into twoPhaseEulerFoam?
Thanks
Old   November 17, 2016, 12:09
rdbisme's Avatar
Ruben Di Battista
Hi Ruben,
Thanks
Well, that's an hard question. Maybe more expert people will be more useful than me. In any case if I remember well in the Rusche thesis twoPhaseEulerFoam solver is based on there was also a chapter on the interface capturing.
By the way I would choose the starting solver on the base of which of the two phenomenon is more important to your case.
Old   November 19, 2016, 18:26
Patricio Bohorquez
pbohorquez is on a distinguished road
Hi Ruben,
Thanks
I did it using the mixture or drift-flux theory some years ago. What you want to do is not easy. See some details in my paper:
Bohorquez, P. Finite volume method for falling liquid films carrying monodisperse spheres in Newtonian regime. AIChE Journal, 58: 2601–2616, 2012 PDF doi:10.1002/aic.13863
pbohorquez is offline   Reply With Quote
Old   November 30, 2016, 09:16
Default multiphase flow in cyclone
  #18
ali
ebtedaei is on a distinguished road
Dear All,
I want to simulate multiphase flow of cyclone in OpenFOAM. I am working on slurry flow that its parameters are as fallows:
Particle size distribution= <70 micron
%solid of slurry= 70-75%
%water of slurry= 25-30%
When flow is pumped to cyclone, Air core is created inside cyclone. There are 3 type phase in cyclone: particle + water + air.
1- What solver is suitable for this flow? twophaseEulerFoam? or settlingFoam? or ...?
2- For example If twophaseEulerFoam solver is Ok, How will I enter the Lagrangian (particle) phase? Please guide about the folders (0 , constant , system) and their parameters.
3- I will use Mixture model, Is there the model in twophaseEulerFoam solver?
Thanks in advance.
Ali
ebtedaei is offline   Reply With Quote
Old   December 1, 2016, 09:05
rdbisme's Avatar
Ruben Di Battista
Originally Posted by ebtedaei View Post
Dear All,
Thanks in advance.
Ali
Well, you have multiple phases. How do you want to treat those phases? You talk about "Lagrangian", then about "mixture model", than about "twoPhaseEulerFoam" that is, as the name says, an Eulerian solver. It (and the more powerful brother multiplePhaseEulerFoam) treat the different phases as Eulerian fields.
There is not an "above all" solver. It depends on how do you want to model the different phases and on how high is the concentration of each of them. Did you check the solvers list? There is driftFluxFoam that, as it is written there,
Solver for 2 incompressible fluids using the mixture approach with the drift-flux approximation for relative motion of the phases.
To understand how the folders are organized, check the tutorial folder of OpenFOAM.
Old   December 1, 2016, 16:33
ali
Thanks for your reply, I will to use twophaseEulerFoam solver with two phases [air + slurry] but the slurry contains water and fine particles (<70 micron)...!
Now,
1- how do I import the particles here so the solver can solve it?
2- Which solver can you suggest for this case?
Thanks,
Ali
pipe flow, sand & water, slurry flow, turbulent flow, twophaseeulerfoam
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
Can OpenFOAM generate flow at the speed of light? Michel_sharp OpenFOAM 6 October 24, 2009 04:09
What is the difference between liquid reactive flow and gas reactive flow? James Main CFD Forum 6 May 15, 2009 12:14
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
