reactingFoam running error
Like Tree1Likes
  • 1 Post By ghazal_1989
Old   January 17, 2017, 10:49
Default reactingFoam running error
Zhenlan GAO
tubois is on a distinguished road
I tried to set up the Tutorial Eleven reacting foam found http://www.cfd.at/downloads/2014_OFoam_Tut_Complete.pdf
I got the error as below. Can someone help me?
| \\ / O peration | Version: v1612+ |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
Build : v1612+
Exec : reactingFoam
Date : Jan 17 2017
Time : 16:47:09
Host : "belledonne"
PID : 6002
Case : /home/gao/OpenFOAM/gao-v1612+/run/counterFlowFlame2D_v2
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Creating reaction model
Selecting combustion model laminar<psiChemistryCombustion>
Selecting chemistry type
chemistrySolver EulerImplicit;
chemistryThermo psi;
Selecting thermodynamics package
type hePsiThermo;
mixture reactingMixture;
transport sutherland;
thermo janaf;
energy sensibleEnthalpy;
equationOfState perfectGas;
specie specie;
Selecting chemistryReader foamChemistryReader
elements not defined in "/home/gao/OpenFOAM/gao-v1612+/run/counterFlowFlame2D_v2/constant/reactions"
chemistryModel: Number of species = 5 and reactions = 1
using integrated reaction rate
Reading field U
Creating turbulence model.
Selecting turbulence model type laminar
Selecting laminar stress model Stokes
Creating field dpdt
Creating field kinetic energy K
No MRF models present
No finite volume options present
Courant Number mean: 2.99581e-08 max: 1.72209e-05
Starting time loop
deltaT = 1.2e-06
Time = 1.2e-06
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
PIMPLE: iteration 1
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
#5 Foam::fluidThermo::nu() const at ??:?
#6 Foam::laminarModels::Stokes<Foam::ThermalDiffusivi ty<Foam::CompressibleTurbulenceModel<Foam::fluidTh ermo> > >::nuEff() const at ??:?
#7 Foam::linearViscousStress<Foam::laminarModel<Foam: :ThermalDiffusivity<Foam::CompressibleTurbulenceMo del<Foam::fluidThermo> > > >::divDevRhoReff(Foam::GeometricField<Foam::Vector <double>, Foam::fvPatchField, Foam::volMesh>&) const at ??:?
#8 ? at ??:?
#9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#10 ? at ??:?
Exception en point flottant (core dumped)
tubois is offline   Reply With Quote
Old   January 18, 2017, 05:27
Zhenlan GAO
The tutorial is prepared with OF 2.3.0
So I run this case with my old version OF 2.4.0 with three small adaptions, the case starts running.
So I am wondering when did OF introduce some bugs here?
Can someone help me to fix the bug? I am new to OF.
Build : v1612+
Exec : reactingFoam
Date : Jan 17 2017
Time : 16:47:09
Host : "belledonne"
PID : 6002
nProcs : 1
Create time
type hePsiThermo;
thermo janaf;
specie specie;
Reading field U
Creating field dpdt
Starting time loop
deltaT = 1.2e-06
Time = 1.2e-06
PIMPLE: iteration 1
#8 ? at ??:?
#10 ? at ??:?
Old   February 21, 2017, 09:20
Default reactingFoam solver errors
ghazal_1989 is on a distinguished road
Hi all,
As a openFoam beginner, I've run a simulation in reactingFoam and unfortunately I just got these codes with No iteration ! Is there anyone who would help me please?
Time = 2.46472e-05
PIMPLE: iteration 1
DILUPBiCG: Solving for O2, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for H2O, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for CH4, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for CO2, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for h, Initial residual = 7.83352e-07, Final residual = 7.83352e-07, No Iterations 0
min/max(T) = 358.241, 1499.98
DICPCG: Solving for p, Initial residual = 5.76649e-07, Final residual = 5.76649e-07, No Iterations 0
time step continuity errors : sum local = 7.65015e-07, global = -2.09684e-17, cumulative = -0.00201457
rho max/min : 2.50857 2.33323e-06
time step continuity errors : sum local = 7.65015e-07, global = -2.08342e-17, cumulative = -0.00201457
ExecutionTime = 118.72 s ClockTime = 120 s
Courant Number mean: 6.95254e-05 max: 0.399999
deltaT = 9.51118e-12
Time = 2.46472e-05
PIMPLE: iteration 1
DILUPBiCG: Solving for h, Initial residual = 7.83341e-07, Final residual = 7.83341e-07, No Iterations 0
time step continuity errors : sum local = 7.65015e-07, global = 3.51658e-18, cumulative = -0.00201457
time step continuity errors : sum local = 7.65015e-07, global = 3.58657e-18, cumulative = -0.00201457
ExecutionTime = 118.77 s ClockTime = 120 s
deltaT = 9.51119e-12
saadouda likes this.
ghazal_1989 is offline   Reply With Quote
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
POSDAT problem piotka STAR-CD 4 June 12, 2009 08:43
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
