February 5, 2017, 14:51 |
Trouble with submitting a compiled case
savita
Rep Power: 9 |
I have compiled a solver and when I try to run the case
the log.case reads as :- Build : dev-2c46bf1554a1 Exec : constvol -parallel Date : Feb 05 2017 Time : 13:33:55 Host : "pn2" PID : 25292 [0] [0] [0] --> FOAM FATAL ERROR: [0] "/usr/people1/krish042/OpenFOAM/krish042-dev/run/SAVITA/const_Vol/Propane1/PROPANE/system/decomposeParDict" specifies 20 processors but job was started with 8 processors. [0] FOAM parallel run exiting [0] Can anyone please suggest some ways to resolve the error? |
February 6, 2017, 03:39 |
Kevin van As
Rep Power: 20 |
Did you read the error...? It tells you exactly what you did wrong.
decomposeParDict" specifies 20 processors but job was started with 8 processors. |
February 6, 2017, 10:25 |
savita
Rep Power: 9 |
Oh yes! Thank you so much
Pressure instabilities with interDyMFoam for the floatingObject case | nbadano | OpenFOAM Running, Solving & CFD | 15 | October 15, 2021 06:35 |
[snappyHexMesh] Editing the motorBike case, loading diffirent .stl | btgyd | OpenFOAM Meshing & Mesh Conversion | 1 | September 26, 2011 17:24 |
Error reading new case | montag dp | FLUENT | 5 | September 15, 2011 06:00 |
UDF compiled error, please help | GBLiu | FLUENT | 4 | June 7, 2006 20:31 |
Turbulent Flat Plate Validation Case | Jonas Larsson | Main CFD Forum | 0 | April 2, 2004 10:25 |
