Boundary conditions symmetryPlane vs zeroGradient
Like Tree15Likes
  • 15 Post By duongquaphim
Old   May 17, 2005, 10:04
Default What is the difference? If I m
Luckyluke
luckyluke is on a distinguished road
What is the difference? If I model the RT instability in a box, what conditions should be set to left,right,top and bottom boundaries for gamma?
Thanks.
luckyluke is offline   Reply With Quote
Old   May 19, 2005, 10:10
Default Who give me a few words? ^_^
Luckyluke
Old   May 19, 2005, 10:14
Default zeroGradient sets the boundary
henry is on a distinguished road
zeroGradient sets the boundary value to the near-wall cell value whereas a symmetryPlane is a symmetry-plane which is the same thing for scalars but not for vectors or tensors.
henry is offline   Reply With Quote
Old   January 15, 2012, 02:06
Default Desciption / maths of symmetryPlane boundary condition
RygeltheXVI is on a distinguished road
Hail,
I'm trying to work out description of what he symmetryPlane boundary condition actually is. I haven't had any luck with either the user nor programmers guide.
This thread gives the most mathematical description that I can find online but is still incomplete:
What is it for vectors? (If it was just normal component zero, then it would be the same as a slip boundary condition).
I have tried but have no luck interpreting the source code: and even then I don't know which one to look at (I don't know which of /src/finiteVolume/fields/fvPatchFields/basic/basicSymmetry or /src/finiteVolume/fields/fvPatchFields/constraint/symmetry [if either, it could be another one] corresponds to symmertyPlane).
If anyone knows which, or preferably a description of what the symmetryPlane boundary condition does, it would be very much appreciated.
Many Thanks
Rygel
RygeltheXVI is offline   Reply With Quote
Old   April 16, 2012, 13:01
Brendan
guitarbren is on a distinguished road
I would also like to know the difference if there is anyone out there with an idea?
Thanks
guitarbren is offline   Reply With Quote
Old   April 23, 2012, 03:18
Default SymmetryPlane facts
Mohammad Fereshtehpour
MOHAMMAD67 is on a distinguished road
Send a message via Skype™ to MOHAMMAD67
Dear Foamers
Is there anyone here help us to have more information about that? I obserevd some differences between the results of the model with and without symmetryPlane?
MOHAMMAD67 is offline   Reply With Quote
Old   December 7, 2012, 22:22
Ali Q Raeini
aliqasemi is on a distinguished road
too late but, I had a quick look, apparently the boundary field is assigned in function: Foam::basicSymmetryFvPatchField<Type>::evaluate. It makes use of transform boundary condition, and I didn't decode it thoroughly. However, my speculation is as follows:
For vector fields, the value of the field on the patches with type "symmetryPlane" are calculated by projecting the patchInternalField to the patch. They are calculated as the average of the patchInternalField values and their mirrors in the patch faces.
aliqasemi is offline   Reply With Quote
Old   December 8, 2012, 08:51
Duong A. Hoang
duongquaphim is on a distinguished road
Send a message via Yahoo to duongquaphim
For zeroGradient, both scalar and vector field are set as the value of the cell near the patch by setting surface normal gradient to 0: grad(f) = (f_P - f_N)/delta = 0 (programmerGuide page 40).
With symmetryPlane, for a scalar, the computation is similar to zeroGradient. For a vector, to make it simple, all components parallel to the patch is mirrored while the normal component is set to zero. Looking at the code of OpenFOAM at src/finiteVolume/fields/fvPatchFields/basic/basicSymmetry, I think they use transformation matrix to compute the new value on the BC. The method can be find in http://en.wikipedia.org/wiki/Householder_transformation
Regards,
Duong
duongquaphim is offline   Reply With Quote
Old   February 11, 2017, 09:12
samane dortaj
sam.dj is on a distinguished road
in tutorials,lagrangian,DPMFoam,goldschmidt, this BC is used for p and u, so we can use it for vectors.
sam.dj is offline   Reply With Quote
Question about symmetryPlane lin OpenFOAM Running, Solving & CFD 0 October 9, 2008 02:30
[snappyHexMesh] SnappyhexMesh and Symmetryplane bastil OpenFOAM Meshing & Mesh Conversion 10 October 7, 2008 17:07
Burgerbs equation non constant Boundary Conditions Initial Conditions arkangel OpenFOAM Running, Solving & CFD 1 October 2, 2008 14:48
SymmetryPlane Boundary Condition raytracer OpenFOAM Running, Solving & CFD 0 July 11, 2008 17:04
Integral boundary conditions turbulent intensitylength boundary conditions olesen OpenFOAM Running, Solving & CFD 0 July 27, 2006 07:18
