February 16, 2017, 11:00 |
Maximum iterations exceeded in rhoSimpleFoam
Peter Shi
Rep Power: 9 |
Hello all,
I am struggling with this problem in the last few days. I have reviewed threads in the forum discussing this error, however I still cannot fix it. It is really a tough one, which is related to many factors. I am working on flow around muti-element airfoil 30p30n, and the flow condition is Ma=0.2, Re=9e6. The initial values of bcs are verified by my incompressible counterparts. The work I am doing is simplely taking into account the compressibility and transforming my simpleFoam setup to rhoSimpleFoam settings. My mesh is quite good, and I attached checkMesh result below. The y+ I utilized is around 1~5, hence wall function is not needed. You can find my folder 0 and folder system in the attachments. No matter what settings I used, the same problem always comes out, i.e. the maximum number of iterations exceeded. Now, I do not know what to do and really hope someone could kindly give me a hand. I appreciate it, and so many thanks. Best regards, Peter. Last edited by PeterShi; February 18, 2017 at 02:32. |
February 25, 2017, 09:29 |
Peter Shi
Rep Power: 9 |
Hi all,
This problem has been solved. I mistakenly set the wrong values of two constants in the sutherland formula. Best, Peter |
February 25, 2017, 12:46 |
jeanpinto24@hotmail.com
Rep Power: 9 |
Could you upload the script with the modification done?
February 25, 2017, 22:10 |
Peter Shi
Rep Power: 9 |
I just set two constants of sutherland, in thermodynamicsproperty, namely As & Ts to the appropriate value for the air. Please notice this is not the only reason for you to run into this problem, but for me, that's it. Hope this will help. Best, Peter |
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 14:26 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 18:17 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
