icoFoam "Continuity error can not be removed by adjusting the outflow"
Old   February 23, 2017, 10:17
Default icoFoam "Continuity error can not be removed by adjusting the outflow"
jeanpinto24@hotmail.com
jeanpinto24| is on a distinguished road
When changing the geometry of the cavity (solver icoFoam) case to a box with a cylindrical inlet and outlet like the attached image, I get the following error:
https://drive.google.com/open?id=0B8...1F1U1JkUko1cDQ
-> FOAM FATAL ERROR:
Continuity error can not be removed by adjusting the outflow.
Please check the velocity boundary conditions and / or run potentialFoam to initialise the outflow.
Total flux: 0.284255
Specified mass inflow: 1246.79
Specified mass outflow: 0
Adjustable mass outflow: 0
From function adjustPhi (surfaceScalarField &, const volVectorField &, volScalarField &)
In file cfdTools / general / adjustPhi / adjustPhi.C at line 118.
The entrance is by the lower cylinder.
I attach the files 0 / U and 0 / p:
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type fixedValue;
value uniform (0 0 1);
exit
type fixedValue;
value uniform (0 0 0);
walls
type fixedValue;
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type zeroGradient;
exit
type zeroGradient;
walls
type zeroGradient;
jeanpinto24| is offline   Reply With Quote
Old   February 23, 2017, 16:53
Wouter van der Meer
wouter is on a distinguished road
hello jeanpinto24|,
setting all inputs and outputs to a fixed value does not work with incompressible flows.
So either set the input or the output and leave the other for example zero gradient.
hope this helps
Wouter
wouter is offline   Reply With Quote
Old   February 24, 2017, 04:44
Default question mark
If the speed at the input can not have a fixed value, how is the input speed defined for the control volume? (Which in my case has a fixed value in the input).
Jean.
Old   February 24, 2017, 05:07
Andrea Di Ronco
Diro7 is on a distinguished road
you can of course set a fixed velocity on the inlet, but you can't set another one at the outlet. icoFoam is a solver for incompressible fluid flows, so total volumetric flow rate must be conserved.
If you set a velocity on the inlet, the actual value at the outlet will be determined by the solution. Also, your inlet and outlet sections seem to be equal, so fixing different velocities at inlet and outlet is totally unphysical!
The usual choice is to set zeroGradient at the outlet, so fixing the gradient the actual value can be determined according the inlet value.
The same holds for pressure: it's common to set a fixedValue at the outlet (typically 0, since the fluid is incompressible only pressure differences matter) and zeroGradient at the inlet.
Andrea
Diro7 is offline   Reply With Quote
Old   February 24, 2017, 05:36
Default .-
Hello Andrea,
Thank you for your thoughts on this case. According to your advice, make a change of the file 0 / U as follows (It is correct that the two cylinders have equal geometry):
FoamFile
Version 2.0;
Format ascii;
Class volVectorField;
Object U;
Dimensions [0 1 -1 0 0 0 0];
InternalField uniform (0 0 0);
BoundaryField
Inlet
Type fixedValue;
Value uniform (0 0 1);
Exit
Type zeroGradient;
Walls
Type zeroGradient;
I kept the file 0 / p:
FoamFile
Version 2.0;
Format ascii;
Class volScalarField;
Object p;
Dimensions [0 2 -2 0 0 0 0];
InternalField uniform 0;
BoundaryField
Inlet
Type zeroGradient;
Exit
Type zeroGradient;
Walls
Type zeroGradient;
I am waiting for the results of the simulation.
Jean.
Old   February 24, 2017, 08:31
Default video of the simulation
https://drive.google.com/file/d/0B89...phdU9FbXc/view
Old   February 24, 2017, 16:45
Wouter van der Meer
hello jeanpinto24|,
now you have set the wall as an outlet. fixed value for the wall of U=(0,0,0) because there is no flow through the wall.
Hope this helps
Wouter
Old   February 25, 2017, 10:51
Default .-
Hi wouter
I will now change from solver of icoFoam to buoyantBoussinesqPimpleFoam, I have the doubt to apply the Contour condition of Temperature, I would do it as follows:
FoamFile
Version 2.0;
Format ascii;
Class VolScalarField;
Object T;
Dimensions [0 0 0 1 0 0 0];
InternalField uniform 300;
BoundaryField
Inlet
Type fixedValue;
Value uniform 500;
Exit
Type zeroGradient;
Walls
Type fixedValue;
Value uniform 300;
Is the procedure for the temperature contour condition correct?
cavity
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 05:28
Continuity error cannot be removed by adjusting the outflow. Please check the velocit range_rover OpenFOAM Running, Solving & CFD 7 August 17, 2016 01:12
Continuity error cannot be removed by adjusting the outflow luisfeliperojas95 OpenFOAM Running, Solving & CFD 1 December 19, 2015 15:12
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
