March 20, 2017, 08:03 |
dQ monitor
Roman
Rep Power: 12 |
Hello. There is a code of the dQ monitor (taken from this forum) that worked fine on the previous versions, but does not work on the latest version of OF.
Please give an idea of how to adapt it to the current version. Such monitor is very useful because displays dQ "on line", during solving, and there is no need starting paraview to be sure that the fire solving is correct. Thanks functions ( volInts { type cellSource; functionObjectLibs ("libfieldFunctionObjects.so"); enabled true; outputControl timeStep; //outputTime; outputInterval 1; log true; //true; valueOutput false; source all; //cellZone; sourceName c0; operation volIntegrate; fields ( dQ ); |
Problem with surface monitor position | jf90cl | FLUENT | 0 | April 28, 2016 11:41 |
Problem with an old Simulation | FrankW | CFX | 3 | February 8, 2016 04:28 |
LES in DES can't be actived! | shenying0710 | CFX | 17 | January 23, 2014 04:45 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
Lift, Drag Vs time chart,calculations | Jamesd69climber | CFX | 8 | February 17, 2005 17:23 |
