inletOutlet B/C doesn't work, cannot stop reverse flow |
April 29, 2017, 07:22 |
Janry
Rep Power: 10 |
Hi foamers,
Recently I was applying inletOutlet boundary conditions for stopping the reverse flow when simulating a 2D- rotor section. However, the case was collapse after running some steps. The reason is that, the inletOutlet boundary condition doesn't really stop the reverse flow. The a strong reverse flow forms a shock wave, messing every thing up. Please see the following picture (Screenshot_2017-04-29_20-36-18.jpg). The boundary condition setup is: Code:
patch_outlet { type inletOutlet; inletValue uniform(0 0 0); } I'll appreciate every comment. Thanks, Janry |
April 30, 2017, 11:21 |
#2 | |
Oskar
Rep Power: 10 |
Hi. I'm a begginer but most of my inletoutlet patch contains "value" parameter.
Maybe You should try: Quote:
Solution is converging but have reverse flow on pressure outlet | Dinesh_Dhande | Main CFD Forum | 2 | March 11, 2018 01:02 |
Reverse Flow In NanoFluid Based Double Pipe Counter Flow Heat Exchanger | nabidinhomessi | FLUENT | 0 | November 15, 2015 09:33 |
Reverse flow at boundary | andyross33 | CFX | 2 | August 27, 2013 13:24 |
momentum & x-vel convergence, and reverse flow problem | cinwendy | FLUENT | 0 | April 17, 2013 02:19 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
