works in serial, but not parallel - GGDH in rhoSimpleFoam
Old   April 30, 2017, 21:22
Default works in serial, but not parallel - GGDH in rhoSimpleFoam
Jack
JackW is on a distinguished road
I have a puzzling issue implementing a solver that incorporates Daly & Harlow's GGDH model in the energy Equation. I have updated the EEqn.H of rhoSimpleFoam to read:
volScalarField fluxTimeScale (
        0.3 * turbulence->mut() / (0.09 * rho * turbulence->k())
    volSymmTensorField alphaEff(
        "alphaEff",
        rho*fluxTimeScale*turbulence->R()
    fvScalarMatrix EEqn
        fvm::div(phi, he)
            he.name() == "e"
          ? fvc::div(phi, volScalarField("Ekp", 0.5*magSqr(U) + p/rho))
          : fvc::div(phi, volScalarField("K", 0.5*magSqr(U)))
        //   - fvm::laplacian(turbulence->alphaEff(), he) // linear
      - fvm::laplacian(alphaEff, he) // non-linear
      - fvm::laplacian(turbulence->alpha(), he)
        fvOptions(rho, he)
I am using the kOmegaSST model, so k(), R() and mut() all return well defined values.
In serial everything runs, but in parallel I get:
[1]
[1]
[1] --> FOAM FATAL ERROR:
[1] Maximum number of iterations exceeded
[1]
[1]     From function thermo<Thermo, Type>::T(scalar f, scalar T0, scalar (thermo<Thermo, Type>::*F)(const scalar) const, scalar (thermo<Thermo, Type>::*dFdT)(const scalar) const, scalar (thermo<Thermo, Type>::*limit)(const scalar) const) const
[1]     in file /home/jack/OpenFOAM/OpenFOAM-2.4.0/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 76.
[1]
FOAM parallel run aborting
I am using sensibleEnthalpy, perfectGas and const for transport. As I run the simulation I watch the h residuals rise and I get a crash after ~5-15 iterations. This is obviously the cause as h is proportional to T. Note I have also tried solving for e.
If I look at the flow in paraview, I see small regions (1 or 2 cells) of |T|>3e+8 (should be 297-330).
Note, this behaviour is reasonably fvScheme/fvSolution dependent and if I change the number of procs and decomposition. Also, I have tried from a converged solution from using the standard heat flux model and an initial condition.
Note that I have two timeVaryingMappedFixedValue boundary conditions.
if anyone can help - thanks! I am guessing it is something to do with the processor boundaries and using the turbulence member functions, but I do not know.
Cheers,
Jack
JackW is offline   Reply With Quote
Old   November 15, 2019, 06:49
mechkween is on a distinguished road
Hi Jack,
Did you manage to find a solution to this problem? I've also implemented a GGDH in the EEqn.H and my simulation crashes stating a floating point exception.
Cheers
mechkween is offline   Reply With Quote
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 11:58
Poisson eq w setReference works serial diverges in parallel tehache OpenFOAM Running, Solving & CFD 5 August 29, 2012 09:41
FLUENT in Windows Serial and Linux Parallel sham83 FLUENT 0 May 31, 2011 23:38
Differences solutions in Parallel and Serial wizard1301 OpenFOAM Running, Solving & CFD 2 January 30, 2009 05:38
Serial run OK parallel one fails r2d2 OpenFOAM Running, Solving & CFD 2 November 16, 2005 12:44
