Is there a way to quickly achieve convergence when residuals are fluctuating! |
May 4, 2017, 10:10 |
vidyadhar
Rep Power: 9 |
Hello All,
I am using a particle tracking solver. Before injecting particles, I am running a single phase flow solution to achieve converged solution. When I monitor my residuals(p, U), I can see they are fluctuating around 1e-02 at high Re. In order to achieve convergence(to get residuals below ~1e-06) quickly, what necessary changes I have to make in my fvSolution. Attached are my fvSolution and fvSchemes files. Thanks in advance! |
May 4, 2017, 17:22 |
Rep Power: 20 |
There are many options since this is a transient simulation. You could run it in PIMPLE mode with underRelaxation, decrease your Co number inside your controlDict, ramp up your corrector loops, set relTol to 0, lower your solution tolerance, switch to schemes that are easier to convergence like upwind for div(phi,U) or Euler for the time. Increase mesh quality etc...depends on where the low residuals are coming from. Since you are running it in single phase you could also maybe use a steady state solver.
May 5, 2017, 05:27 |
#3 | |
vidyadhar
Rep Power: 9 |
I have increased the corrector loops to 4 from 2. It resulted in fall of pressure residuals. May I know why this occur? Also if possible, I request you to go through Posts 13 and 18 in this link and let me know about this too: Convergence in OpenFoam Thanks! |
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
Script for plotting Convergence Residuals | Bensmeat | OpenFOAM Post-Processing | 2 | March 5, 2019 12:28 |
Fluctuating residuals for all the parameters | jhssyb | FLUENT | 0 | January 7, 2016 21:12 |
Is this convergence real? | Chander | CFX | 8 | October 21, 2011 19:59 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
