May 13, 2017, 13:34 |
internaldfield temperature
alberto
Rep Power: 10 |
I want to put this boundary condition but i have this error.
wallporosity is the wall of inmersed body. i need because i put no slip condition. can anyone help me with this error? wallporosity { type calculated; value $internalField; } --> FOAM FATAL ERROR: [3] cannot be called for a calculatedFvPatchField on patch wallporosity of field h in file "/home/terofluidos/Documentos/completo/completo/otrointento1/processor3/0/h" You are probably trying to solve for a field with a default boundary condition. [3] [3] From function Foam::tmp<Foam::Field<Type> > Foam::calculatedFvPatchField<Type>::gradientIntern alCoeffs() const [with Type = double] [3] in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 187. [3] FOAM parallel run aborting [3] [2] [2] [2] --> FOAM FATAL ERROR: [2] cannot be called for a calculatedFvPatchField on patch wallporosity of field h in file "/home/terofluidos/Documentos/completo/completo/otrointento1/processor2/0/h" You are probably trying to solve for a field with a default boundary condition. [2] [2] From function Foam::tmp<Foam::Field<Type> > Foam::calculatedFvPatchField<Type>::gradientIntern alCoeffs() const [with Type = double] [2] in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 187. [2] FOAM parallel run aborting [2] [0] [0] [0] --> FOAM FATAL ERROR: [0] cannot be called for a calculatedFvPatchField on patch wallporosity of field h in file "/home/terofluidos/Documentos/completo/completo/otrointento1/processor0/0/h" You are probably trying to solve for a field with a default boundary condition. [0] [0] From function Foam::tmp<Foam::Field<Type> > Foam::calculatedFvPatchField<Type>::gradientIntern alCoeffs() const [with Type = double] [0] in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 187. [0] FOAM parallel run aborting [0] [1] [1] [1] --> FOAM FATAL ERROR: [1] cannot be called for a calculatedFvPatchField on patch wallporosity of field h in file "/home/terofluidos/Documentos/completo/completo/otrointento1/processor1/0/h" You are probably trying to solve for a field with a default boundary condition. [1] [1] From function Foam::tmp<Foam::Field<Type> > Foam::calculatedFvPatchField<Type>::gradientIntern alCoeffs() const [with Type = double] [1] in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 187. [1] FOAM parallel run aborting [1] |
May 15, 2017, 06:17 |
Tung
why do you use calculated BC?
please explain your case more specific |
Shadow Wall and temperature | norger | FLUENT | 10 | September 28, 2019 11:43 |
Static temperature and Total temperature | Jong-Yoon | FLUENT | 0 | September 25, 2016 01:42 |
fluid flow but temperature raises from nowhere? | mxcfd | STAR-CCM+ | 5 | September 16, 2014 05:46 |
How to get free stream temperature in boundary condition | saharesobh | FLUENT | 0 | October 9, 2012 17:12 |
monitoring point of total temperature | rogbrito | FLUENT | 0 | June 21, 2009 17:31 |
