High flow and pressure in peripheral reagion of Hele-Shaw cell |
May 19, 2017, 09:07 |
David Taylor
Dear co-foamers,
I am using twoLiquidMixingFoam to simulate laminar, incompressible flow of two miscible liquids in a Hele-Shaw cell. The cell is open on the edges (BC U: pressureinletOutletVelocity p: totalPressure) and has two connections close to the center with flow directions perpendicular to the orientation of the cell. The cell is filled with species A and species B is injected through on aperture and reaspirated at a higher flow rate through the second neighbouring aperture (BC U: fixedValue, p: fixedFluxPressure). Walls are walls (BC U: noSlip, p: fixedFluxPressure). When simulating this, I nicely see the confinement of the injected species B and thigs in general look OK, but I get a max in flow and pressure in a region of my cell where actually nothing much happens and flow should be just radially directed inwards. Can anyone please give me a hint on what I might be doing wrong (the Mesh seems to be OK)? Thank you very much in advance! Best regards, David HeleShawTrouble_David.jpg MeshRect250_10.jpg PS: one of the pioneering papers regarding this idea confining flows in such an arrangement, in case you are interested http://www.nature.com/nmat/journal/v.../nmat1435.html). |
May 26, 2017, 10:04 |
David Taylor
Edit: solved the issue by going into fvSolution and switching from nOuterCorrectors = 0 to nOuterCorrectors = 50 (and implementing an abort condition when the residuals become smaller than a defined threshold, so that not all 50 iterations have to be made each cycle). If I understand correctly, with the previous setting I was running my PIMPLE solver in PISO mode, now it's true PIMPLE. Simulations are still running, but stuff looks promising. Fingers crossed
hele-shaw, twoliquidmixingfoam, unphysical peaks |
BC for Actuator Disk - Flow Vel from High Pressure to Low Pressure | vinguva | OpenFOAM Running, Solving & CFD | 2 | March 7, 2016 23:46 |
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC | Endel | OpenFOAM Running, Solving & CFD | 3 | September 11, 2014 16:29 |
reference pressure and compressible flow | bingo10 | CFX | 0 | September 11, 2013 07:32 |
lid-driven cavity in matlab using BiCGStab | Don456 | Main CFD Forum | 1 | January 19, 2012 15:00 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
