SimpleFoam, komegaSST, low Re approach
Old   May 22, 2017, 13:23
Default SimpleFoam, komegaSST, low Re approach
Jon
jonmartinez1994 is on a distinguished road
I am simulating the flow inside an electronic box. The air flow comes in from two inlets and goes out from one outlet. Inside the box the heat that comes out of the components is taken away by convection. I have been simulating this problem for the past months but I am not sure what I could be doing wrong because I do not get physical results.
I am trying a low Reynolds approach (1<y+<5) for which I refined the mesh a lot and set what I thought to be the proper BCs for k, omega and nut.
Here are the files for the simplest case (an empty box): the 0/ files, fvSolution, fvSchemes and the checkMesh.log
Thank you all in advance!
jonmartinez1994 is offline   Reply With Quote
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 15:26
Problem running simpleFoam with kOmegaSST turbulence model matzbanni OpenFOAM Running, Solving & CFD 5 November 3, 2012 06:45
MPI Error - simpleFoam - Floating Point Exception scott OpenFOAM Running, Solving & CFD 3 April 13, 2012 16:34
simpleFoam Foam::error::printStack(Foam::Ostream&)kOmegaSSTCo effs Verfblikje OpenFOAM Running, Solving & CFD 1 February 27, 2012 05:15
Trying to run a benchmark case with simpleFoam spsb OpenFOAM 3 February 24, 2012 09:07
