Fluent Periodic flow error
Old   November 24, 2008, 08:50
Default Hi all, I am trying to cre
Debashis Maji
debashis is on a distinguished road
Hi all,
I am trying to creat a periodic zone, but hav got the following error :
>grid/modify-zones/make-periodic
Periodic zone [()] 6
Shadow zone [()] 5
Rotational periodic? (if no, translational) [yes] no
Create periodic zones? [yes] yes
Auto detect translation vector? [yes] yes
Warning: differing number of faces on these threads.
computed translation deltas: -0.000436 -0.000421 -0.200000
zone 6: matched 0 out of 500 faces.
zone 5: matched 0 out of 600 faces.
Error: Failed to make zones periodic.
Error Object: #f
can anybody please help me with the msg. I cant understand what it means?
debashis is offline   Reply With Quote
Old   June 27, 2012, 08:03
Marx
Marx is on a distinguished road
Normally there could two reason for this error. First check the origin of rotation. So how do we check, open the design in design modeler then use point entity to check the centre of rotation coordinate. u can even draw on the surface of your model and find the centre of rotation. (anyway works). if its rotating along z axis then get the x and y coordinate and place it in fleunt>cell zone condition> rotation axis origin.
if it does work then maybe its due to different number of cell on the face of the two surface. It a non conformal periodic.(https://www.sharcnet.ca/Software/Flu...ug/node186.htm) you have change the type of B.c from wall to interface then use Mesh Interface where you select the surfaces, check the periodic B.C set the angel offset and create periodic.
Marx is offline   Reply With Quote
Old   May 24, 2017, 06:24
Default similar problem
Sagar Deshmukh
Sagar7 is on a distinguished road
Hey, I am having a similar problem, how you get rid of it? Please help
Thanks in advance
Sagar7 is offline   Reply With Quote
highly compressible flow : Fluent Error Message Amit Shrestha FLUENT 5 December 19, 2018 07:43
Error for periodic boundary in GAMBIT Karim FLUENT 0 August 25, 2007 02:45
error: no periodic nodes on thread __. HELP !!! bne FLUENT 0 June 20, 2007 11:57
error: wall-boundary-periodic! h6h6 FLUENT 0 May 31, 2004 04:04
Fluent error in periodic PDF combustion cases?? George FLUENT 2 March 8, 2004 16:45
