Mapping values with different domains, water channel |
June 20, 2017, 05:47 |
Kim Le
Rep Power: 10 |
Hello everyone,
I am trying to simulate particles transport in a water channel. So first, I have simulated water running in the channel with air on top of it using interFoam. I have unphysical results at the outlet such as in the topic HTML Code:
https://www.cfd-online.com/Forums/openfoam-solving/93702-channel-flow-using-interfoam.html I want to use the latest results of this interFoam simulation, only for the U file, as initial conditions. Problem is the domain is now smaller than the first simulation (but more cells). It seems that mapFields is not ok with that. Does anyone know how to solve this problem ? I have already studied the hopper tutorial. Thanks ! |
June 22, 2017, 08:39 |
Kim Le
Rep Power: 10 |
Maybe mapFields does not work for mapping fields with different geometries but it should not be the case, is it ?
I have put the name of the new patch that has been created and that is kind of slicing the old domain. (in cuttingPatches) But I still can't map my U field... If anyone has the solution, thanks ! Old domain : https://drive.google.com/open?id=0B7...lJ0MG1nd1NFNEU New domain : https://drive.google.com/open?id=0B7...1VERS1wMVZ3ODg |
Mapping values from 2D mesh to 3D mesh boundary during runtime | benk | OpenFOAM Programming & Development | 1 | June 13, 2014 02:39 |
evaporation of liquid water in a horizonal channel | Ahmad Al-Zoubi | CFX | 2 | February 2, 2007 04:55 |
Water vapour condensation in CFX-5.7.1 | hdj | CFX | 1 | November 27, 2005 07:15 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
