buoyantBoussinesqSimpleFoam - continuity error
Like Tree2Likes
  • 1 Post By greel
  • 1 Post By Kanarya
Old   January 3, 2012, 14:37
Question buoyantBoussinesqSimpleFoam - continuity error
Vitor Vasconcelos
vitors is on a distinguished road
Hello all,
I am new to OpenFoam and I'm trying to solve a simple (at last I think it is...) case in which I have a heated rod inside a pipe. For natural convection it seems ok.
When I try to start a flow (inlet and outlet flows) I get a "continuity error message".
I based the configuration files on "hotRoom" OpenFoam's tutorial case.
The boundary conditions are:
p: inlet -> zeroGradient
outlet -> FixedValue uniform 0;
insideWall -> zeroGradient;
outsideWall -> zeroGradient;
U: inlet -> FixedValue (0 1 0)
outlet -> ZeroGradient (or calculated $internalField;
insideWall -> FixedValue (0 0 0);
outsideWall -> FixedValue (0 0 0);
T: inlet -> FixedValue 300;
outlet -> zeroGradient (or calculated $internalField);
insideWall -> FixedValue 1000;
outsideWall -> FixedValue 300;
So, any suggestions?
Thanks in advance.
Vitor
vitors is offline   Reply With Quote
Old   January 4, 2012, 04:00
romant's Avatar
Roman Thiele
romant is on a distinguished road
Originally Posted by vitors View Post
Hello all,
Thanks in advance.
Vitor
For your pressure, you should set the boundary condition to buoyantPressure
for the outlet velocity condition try pressureInletOutletVelocity with value (0 0 0).
~roman
romant is offline   Reply With Quote
Old   January 4, 2012, 09:02
andres
greel is on a distinguished road
I always use this bc in p_rgh
wall
type buoyantPressure;
rho rhok;
value uniform 0;
outlet
type zeroGradient;
inlet
type fixedValue;
value uniform 0;
Mahmoud Abbaszadeh likes this.
greel is offline   Reply With Quote
Old   January 12, 2012, 09:14
Vitor Vasconcelos
Thanks guys. I got a better result, though not perfect. But with this buoyantPressure BC I'll try to tune my simulation.
Old   September 21, 2012, 04:55
Thumbs up Divergence problem solved by Greel's suggestion
Ameya Durve
ameyadurve is on a distinguished road
@ Greel:
Boundary conditions for p_rgh suggested by you worked for my simulation.
I was having a divergence problem for buoyantBoussinesqSimpleFoam that got solved with those boundary conditions.
How good the results are, remains to be seen.
Thanks a lot
Ameya
ameyadurve is offline   Reply With Quote
Old   April 29, 2015, 16:25
Kanarya is on a distinguished road
How was the results?
I have similar doubts about p and p_rgh boundary conditions in buoyantBoussinesqSimpleFoam solver applied in simple pipe simulation...
thanks!
Originally Posted by ameyadurve View Post
@ Greel:
Thanks a lot
Ameya
Kanarya is offline   Reply With Quote
Old   June 13, 2022, 10:48
Mahmoud
Mahmoud Abbaszadeh is on a distinguished road
Dear Foamers,
It’s been a while that I’ve had the same problem in setting the correct BC for similar problems. Here is the review of how I solved this issue:
Problem: steady state open channel flow simulation. In this scenario, normally the simpleFoam is employed. The BCs are given by:
BCs: inlet, outlet, wall, topWall
U:
inlet
type fixedValue;
value uniform (0 0.1589 0);
outlet
type zeroGradient;
wall
type noSlip;
atmosphere
type slip;
p:
atmosphere
type zeroGradient;
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
wall
type fixedFluxPressure; //remember that we cannot use Drichlet and Neuman BC at the same time
value uniform 0;
As one can see, selecting fixedValue BC for the outlet pressure is physically incorrect even though one can get result. To resolve this issue, I decided to use the hydrostatic pressure as the outlet BC for the pressure. To this end, one need to either define gravity in the governing equation or else use a steady state solver that has gravity in the equations. I went for the second approach. The only available solver for incompressible fluids that has this feature is buoyantBoussinesqSimpleFoam. When this solver is selected, the BCs needs to be defined for the U, p, and p_rgh. Generally, p_rgh=p-rho*g*h. I have searched a lot and finally could find the correct way of setting BC for the foregoing parameters.
U:
inlet
type fixedValue;
outlet
type pressureInletOutletVelocity;
value uniform (0 0 0);
inletValue uniform (0 0 0);
wall
type noSlip;
atmosphere
type slip;
P:
atmosphere
type zeroGradient;
inlet
type zeroGradient;
outlet
type calculated;
value $internalField;
wall
type zeroGradient;
P_rgh
inlet
outlet
type fixedValue;
value uniform 0;
wall
atmosphere
let me know if it is not clear.
Keep Foaming
Mahmoud Abbaszadeh is offline   Reply With Quote
boundary conditions, buoyantboussinesqsf, continuity error
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 04:53
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 05:18
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
user defined function cfduser CFX 0 April 29, 2006 10:58
