sonicFoam mesh scale dependence?
Old   August 3, 2017, 13:16
Default sonicFoam mesh scale dependence?
James Feng
fengjq is on a distinguished road
I was running sonicFoam for a de Laval nozzle that has a throat radius around 0.2mm, and could not get it going (crashed right away). Then, I increased the scale such that the throat radius became 2cm, and it ran fine. Is there somewhere I can set for the sonicFoam solver such that it's independent of the length scale of my mesh? Thanks.
fengjq is offline   Reply With Quote
Old   August 4, 2017, 15:09
James Feng
Out of curiosity, I turned off the turbulence model and had successful run for the case of 0.2mm throat radius. So, I guess the length scale dependence must come from the turbulence BC such as the value of epsilon at inlet, etc.
Mesh not modified while shape optimization dolfyn SU2 Shape Design 0 May 3, 2017 21:20
LES Mesh Scale AS_Aero Mesh Generation & Pre-Processing 0 March 8, 2017 03:08
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
