Propeller tutorial isn't working under of1706 |
November 28, 2017, 06:22 |
#1 | ||
Paul Palladium
Rep Power: 10 |
CLOSED : I am sorry I was running an old version of the tutorial from 16.06. The new syntax is :
Dear Foamer, I am trying to run the propeller test case (pimpleDyMFoam solver) but it seems that dynamicFvMesh has changed. When you try to run the solver you get : Quote:
Thanks a lot for your help, Fauster Last edited by Fauster; November 28, 2017 at 06:29. Reason: CLOSED |
November 7, 2018, 09:06 |
Christophk
Rep Power: 7 |
Hello I may try to run the same case.
I get the error as well and tried to use your code, but I can't make it work. Can someone help? Code:
dynamicFvMesh dynamicMotionSolverFvMesh; motionSolverLibs ( "libfvMotionSolvers.so" ); motionSolver solidBody; solidBodyMotionFvMeshCoeffs { cellZone innerCylinderSmall; solidBodyMotionFunction rotatingMotion; rotatingMotionCoeffs { origin (0 0 0); axis (0 1 0); omega 158; // rad/s } } |
July 17, 2019, 05:18 |
#3 | |
Praphul T
Rep Power: 12 |
I think that is because you have defined the solidBodyMotionFunction inside solidBodyMotioNFvMeshCoeffs. Specify it in a similar format as given by Fauster. The code will look like this in that case : Code:
dynamicFvMesh dynamicMotionSolverFvMesh; motionSolverLibs ( "libfvMotionSolvers.so" ); motionSolver solidBody; cellZone innerCylinderSmall; solidBodyMotionFunction rotatingMotion; rotatingMotionCoeffs { origin (0 0 0); axis (0 1 0); omega 158; // rad/s } |
uniformValue table meaning in propeller tutorial | donQi | OpenFOAM Running, Solving & CFD | 12 | November 3, 2022 07:54 |
Marine propeller tutorial / validation case | cagriaydin | FLUENT | 0 | July 28, 2015 10:30 |
Tutorial required for air flow simulation of working space (i.e. office)) | sumeetkotak | FLUENT | 0 | July 7, 2015 12:50 |
DPM parallel is not working but serial is working | johnwinter | FLUENT | 1 | March 27, 2012 02:01 |
Rotor/stator tutorial, and how to... | gilberto | CFX | 5 | January 21, 2002 09:41 |
