October 31, 2022, 06:08 |
nan error with reactingFoam
Jiaqi Sun
Rep Power: 4 |
Hi all,
I am getting an error that the physical quantity is nan using reactingFoam with the following error code. Code:
PIMPLE: iteration 3 smoothSolver: Solving for Ux, Initial residual = 0.00175845, Final residual = 1.05438e-07, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.00208502, Final residual = 1.44881e-07, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.00189283, Final residual = 1.31826e-07, No Iterations 2 DILUPBiCGStab: Solving for AIR1, Initial residual = 0.000448941, Final residual = 5.89385e-09, No Iterations 1 smoothSolver: Solving for h, Initial residual = 0.00361274, Final residual = 1.41976e-07, No Iterations 2 min/max(T) = 290.224, 312.194 GAMG: Solving for p, Initial residual = 0.00631744, Final residual = 1.81504e-06, No Iterations 1 GAMG: Solving for p, Initial residual = 1.81398e-06, Final residual = 1.81398e-06, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 3.52147e-08, global = -4.85416e-10, cumulative = -1.48771e-07 PIMPLE: not converged within 3 iterations ExecutionTime = 2191.31 s ClockTime = 2268 s Courant Number mean: 0.0646922 max: 0.500046 deltaT = 9.8345e-08 Time = 0.000250921 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 PIMPLE: iteration 1 smoothSolver: Solving for Ux, Initial residual = 0.00103463, Final residual = 6.86593e-07, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = nan, Final residual = nan, No Iterations 1000 smoothSolver: Solving for Uz, Initial residual = 0.00115124, Final residual = 8.4355e-07, No Iterations 1 DILUPBiCGStab: Solving for AIR1, Initial residual = 0.00142109, Final residual = 1.16887e-07, No Iterations 1 smoothSolver: Solving for h, Initial residual = nan, Final residual = nan, No Iterations 1000 [21] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [1] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [25] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [24] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [7] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [3] #0 Foam::error::printStack(Foam::Ostream&) at ??:? Last edited by forAurora; October 31, 2022 at 06:11. Reason: wrong spelling |
Error running result | changshuqi | REEF3D | 2 | March 24, 2022 19:57 |
Need Help Here! nan value error | mgkid3310 | OpenFOAM Running, Solving & CFD | 1 | October 6, 2016 00:59 |
Why simulation results showing "nan" values? | Sargam05 | OpenFOAM | 4 | September 10, 2012 12:37 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
