buoyantBoussinesqSimpleFoam with ExternalHeatFluxTemperature
Like Tree5Likes
  • 1 Post By Quadrolabs
  • 4 Post By tomf
Old   October 3, 2017, 16:55
Default buoyantBoussinesqSimpleFoam with ExternalHeatFluxTemperature
Kasper De Geeter
mozeven is on a distinguished road
Dear Community,
I am trying to simulate the flow through a simple heat exchanger. What I am trying to simulate (simplified) is a peltier dumping heat into a heatexchanger. Below you can find a figure explaining the simplified setup.
I am using openFoam V5.0. My case is set up to use the buoyantBoussinesqSimpleFoam solver.
Please find the full case here:
Full case
My model is running and converging when using fixed temperature boundary conditions. However, I have not understood how to add a heat flux boundary condition. I tried to use the externalWallHeatFluxTemperature boundary condition, but was not able to set it up correctly.
checkMesh returns the following:
https://www.dropbox.com/s/hik8gp0oua...kMesh.log?dl=0
https://www.dropbox.com/s/2tioav0723...vSolution?dl=0
https://www.dropbox.com/s/t19m0dqd5t...fvSchemes?dl=0
The T file is as follows:
|  \\    /   O peration     | Version:  4.1                                   |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 275;
boundaryField
    wall
      type          externalWallHeatFluxTemperature;
      mode          power;
      Q             500;
      kappaMethod	fluidThermo;
      kappaName		default;
      Ta            constant 350.0;
      value         uniform 350;
    inlet
        type	fixedValue;
        value	uniform 275;
    outlet
      type  zeroGradient;
The output (including the error) I get is the following:
|  \\    /   O peration     | Version:  5.0                                   |
Build  : 5.0-dbb428a3a855
Exec   : buoyantBoussinesqSimpleFoam
Date   : Oct 02 2017
Time   : 23:52:47
Host   : "kasper-PC"
PID    : 16539
I/O    : uncollated
Case   : /home/kasper/OpenFOAM/kasper-5.0/run/HeatBlock_power
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
SIMPLE: convergence criteria
    field p_rgh	 tolerance 0.01
    field U	 tolerance 0.0001
    field T	 tolerance 0.001
    field "(k|epsilon|omega)"	 tolerance 0.001
Reading thermophysical properties
Reading field T
Reading field p_rgh
Reading field U
Selecting incompressible transport model Newtonian
Creating turbulence model
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
RAS
    RASModel        kEpsilon;
    turbulence      on;
    printCoeffs     on;
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              0;
    sigmak          1;
    sigmaEps        1.3;
Reading field alphat
Reading g
Reading hRef
Calculating field g.h
No MRF models present
Radiation model not active: radiationProperties not found
Selecting radiationModel none
No finite volume options present
Starting time loop
Time = 1
DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 0.0157593, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 0.0157414, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 1, Final residual = 0.0187311, No Iterations 1
--> FOAM FATAL ERROR:
Kappa defined to employ fluidThermo method, but thermo package not available
    From function Foam::tmp<Foam::Field<double> > Foam::temperatureCoupledBase::kappa(const scalarField&) const
    in file turbulentFluidThermoModels/derivedFvPatchFields/temperatureCoupledBase/temperatureCoupledBase.C at line 135.
FOAM exiting
Can someone point me to a minimum working example using buoyantBoussinesqSimpleFoam and externalWallHeatFlux? Or tell me what I am doing wrong?
For information, my next step in this model will be to include the body of the heat exchanger as a solid and have the heatflux boundary condition on one of the walls of the solid. I intend to do that by changing the solver to chtMultiRegionSimpleFoam. This is why in my current model I did not separate a single wall to apply the heatflux to as the wall from the fluid domain will be touching the solid.
I hope to have given enough information for someone to be able to give me some pointers on what I am doing wrong. If more information is required, please ask.
Thanks in advance,
Kasper
mozeven is offline   Reply With Quote
Old   October 3, 2017, 22:00
Quadros
Quadrolabs is on a distinguished road
Hello kasper.
Actually I dont know about fixedWallHeatFluxTemperature but for specifying heat flux from wall as boundary condition there is one way. You can specify it as fixedGradient in the temperature file. The gradient can be found from fourier law of heat conduction Q = -k(dT/dy). so you are calculating
dT/dy = -Q/k.
I hope this will solve your problem. In case if you find someother method kindly update.
Thank you.
sonGoku likes this.
Quadrolabs is offline   Reply With Quote
Old   October 4, 2017, 02:53
Kasper De Geeter
Originally Posted by Quadrolabs View Post
Hello kasper.
dT/dy = -Q/k.
Thank you.
Thanks for that tip. I will give that a try tonight.
However, I still don't see why the externalWallHeatFluxTemperature BC doesn't work. Looking at the documentation I don't see what I am doing wrong. Someone more experienced than me might find something obvious.
Kind regards,
Kasper
Old   October 4, 2017, 05:32
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hello Kasper,
The problem you are facing stems from the fact that buoyantBoussinesqSimpleFoam is for incompressible fluids, while the externalWallHeatFluxTemperature boundary condition is for compressible fluids.
You may want to work with buoyantSimpleFoam and use the Boussinesq equation of state:
|  \\    /   O peration     | Version:  5                                     |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      thermophysicalProperties;
thermoType
    type            heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState Boussinesq;//perfectGas;
    specie          specie;
    energy          sensibleEnthalpy;
mixture
    specie
        molWeight       28.96;
    thermodynamics
        Cp              1004.4;
        Hf              0;
    transport
        mu              1.831e-05;
        Pr              0.705;
    equationOfState
        rho0            1.225;
        T0              293.15;
        beta            3.411e-3;
tomf is offline   Reply With Quote
Old   October 5, 2017, 17:03
Kasper De Geeter
Hi Tom,
Thanks for your help. I tried it and indeed, everything is now working.
For some reason, when I decompose my case, I had an error, because the solver cannot find Ta, which according to the documentation (and when running single core) is not necessary. I solved it by manually adding it to the decomposed T files, but it's annoying...
Is there any way I could have known that this boundary condition only works on compressible solvers? I found no reference to it in the documentation.
Kind regards,
Kasper
Old   October 6, 2017, 04:20
Tom Fahner
If you do a find in a terminal:
find $FOAM_SRC -iname *externalWallHeatFluxTemperature*
it shows that it is a derived boundary condition in compressible turbulencemodels:
src/TurbulenceModels/compressible/turbulentFluidThermoModels/derivedFvPatchFields/externalWallHeatFluxTemperature
That is usually a hint. I have not looked into the code or documentation for this.
Regards,
Tom
boundaries condition, buoyantboussinesqsimple, heat exchanger, heat flux
