Lagrange particles not moving
Like Tree1Likes
  • 1 Post By obiscolly50
Old   February 10, 2019, 11:37
Default Lagrange particles not moving
Obi
obiscolly50 is on a distinguished road
Hello all,
I modified a simplefoam solver to include temperature, porous media and lagrange particle tracking. I'm trying to solve the flow for a steady-state case in parallel, but i'm experiencing a strange problem. I'm using the flow field from an already converged case as the initial 0 field. After introducing the particles at the inlet patch they remain roughly in the same position for subsequent iterations.
Below is the kinematicCloudProperties file i'm using which was derived from the steady-state particle solver simpleReactingParcelFoam particle properties file.
I'm supsecting two issues:-
1) The particles are stuck just before the first porous zone. I implemented the porosity as a momentum sink in the UEqn not as a physical barrier and didn't think this would be an issue since the particle should take the path of least resistance.
2) I'm setting something wrong in my kinematicCloudProperties file. I've not used steady-state particle tracking before and just used the file fro simpleReactingParcelFoam with very little modification.
Anyone with any idea of what could be wrong. I'm using the openFoam v6.
|  \\    /   O peration     | Version:  4.x                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      kinematicCloudProperties;
solution
    active          true;
    coupled         false;
    transient       no;
    calcFrequency   10;  //added
    maxTrackTime    5; //added
    cellValueSourceCorrection off;
    maxCo           0.3;
    interpolationSchemes
        rho             cell;
        U               cellPoint;
        mu              cell;
        DUcDt           cell;
    integrationSchemes
        U               Euler;
	T               analytical;
    sourceTerms
	resetOnStartup  no; //added
        schemes
            U           semiImplicit 1;
constantProperties
    rho0            1200; //was 8800
    youngsModulus   1.3e5;
    poissonsRatio   0.35;
subModels
    particleForces
        sphereDrag;
        gravity;
        pressureGradient
            U U;
    injectionModels
	model1
            type             patchInjection;
	    massFlowRate     0.8e-04;
            parcelBasisType  mass;
            patchName        influent;
	    parcelsPerSecond 1000;
            duration         1;  //set to 1 for steady state
            U0               (-60 0 0);
            flowRateProfile  constant 1;
            //nParticle        1;
            //SOI              10;
            sizeDistribution
                type        fixedValue;
                fixedValueDistribution
                    value   15e-6;
    dispersionModel none;
    patchInteractionModel  localInteraction; //was standardWallInteraction
    localInteractionCoeffs
        patches
            "effluent|soldischarge"
                type escape;
                type rebound;
                e    0.97;
                mu   0.09;
    surfaceFilmModel none;
    stochasticCollisionModel none;
    collisionModel none;
    pairCollisionCoeffs
        maxInteractionDistance  0.00007;
        writeReferredParticleCloud no;
        pairModel pairSpringSliderDashpot;
        pairSpringSliderDashpotCoeffs
            useEquivalentSize   no;
            alpha               0.12;
            b                   1.5;
            mu                  0.52;
            cohesionEnergyDensity 0;
            collisionResolutionSteps 12;
        wallModel wallSpringSliderDashpot;
        wallSpringSliderDashpotCoeffs
            youngsModulus   1e10;
            poissonsRatio   0.23;
            alpha           0.12;
            b               1.5;
            mu              0.43;
cloudFunctions
    particleTracks1
        type            particleTracks;
        trackInterval   5;
        maxSamples      1000000;
        resetOnWrite    yes;
Below is the picture of the particles stuck at the porous zone.
Last edited by obiscolly50; February 10, 2019 at 12:19. Reason: added more details
obiscolly50 is offline   Reply With Quote
Old   March 2, 2019, 16:40
Obi
Eventually figured out the problem. I increased the maxTrackTime to a higher value. Now the particles move past the region.
rugg.das likes this.
Old   May 12, 2019, 06:06
Default Lagrangian particles + thermal transport
manalis is on a distinguished road
Originally Posted by obiscolly50 View Post
Hello all,
I modified a simplefoam solver to include temperature, porous media and lagrange particle tracking. I'm trying to solve the flow for a steady-state case in parallel...
Hello obiscolly,
As I've been working on similar cases, I have a quick question: how did you handle the thermal transport to particles? I am asking this because normally the "thermo" library for particles (and generally for fluids, if I am not mistaken) is associated with compressible solvers. So, isn't it incompatible with an incompressible solver like "simpleFoam" by default?
Regards
manalis is offline   Reply With Quote
Old   May 25, 2019, 17:09
Obi
Originally Posted by manalis View Post
Hello obiscolly,
Regards
I didn't consider heat transfer from/to particles for my analysis unfortunately. I believe some of the particle tracking classes already take this into consideration by using particle properties such as specific heat e.g reactingCloud. But i didn't need that for my analysis. It would probably be more compatible with a solver like chtMultiRegionFoam which can also be used for incompressible.
Old   October 9, 2020, 11:42
Ruggiero
rugg.das is on a distinguished road
Hi obiscolly,
I'm a real beginner in OpenFoam and I'm trying to implement the lagrangian particle transport on a steady-state problem.
I followed the tutorial https://www.foamacademy.com/wp-conte...les_slides.pdf, but on a SIMPLE scheme. I followed the same steps as in the tutorial and the compilation was successful.
I am doing verification tests on the pitzdaily tutorial, but no particle is traced (kinematicCloud folder is not created after the foamToVTK command).
What I can display in paraview is just the solid fraction, and it seems that solid particles don't evolve through the domain, even if I increase the maxTrackTime value.
Which value do you suggest?
Have you ever experienced this issue? Have you found a way to overcome it?
I'm working on OpenFoam 4.x.
Thank you very much for your support.
Any suggestion will be very much appreciate.
rugg.das is offline   Reply With Quote
Problem with DPM simulation with particles injection and EXECUTE_AT_THE_END UDF. Ari Fluent UDF and Scheme Programming 4 May 31, 2016 08:51
dsmcFoam - micro-hole limiting the number of dsmc particles Araist OpenFOAM Running, Solving & CFD 0 June 25, 2015 06:50
Add lagrangian particles to OpenFoam solver luchen2408 OpenFOAM 0 June 2, 2015 03:10
Question on moving mesh, mesh velocity is really small! ripperjack Main CFD Forum 2 April 28, 2014 13:37
particles model ati_ros61 FLOW-3D 3 December 6, 2009 16:03
