Another 'Time step continuity error' thread
Like Tree1Likes
  • 1 Post By jaydeep
Old   November 14, 2017, 07:17
Default Another 'Time step continuity error' thread
Deep
deepbandivadekar is on a distinguished road
Can someone please help me with the time step continuity error I'm getting?
I'm using simpleFoam and this is what I get when I run the case
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) at ??:?
#4  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
#5  ? at ??:?
#6  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#7  ? at ??:?
In the log file the last entries are like this:
Time = 8
DILUPBiCG:  Solving for Ux, Initial residual = 0.954901, Final residual = 0.072332, No Iterations 71
DILUPBiCG:  Solving for Uy, Initial residual = 0.94901, Final residual = 0.0562591, No Iterations 68
DICPCG:  Solving for p, Initial residual = 0.999999, Final residual = 0.0958529, No Iterations 293
time step continuity errors : sum local = 3.77895e+12, global = -1.04947e+10, cumulative = -1.04947e+10
ExecutionTime = 0.53 s  ClockTime = 1 s
Time = 9
DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 0.0892879, No Iterations 261
DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 0.0170661, No Iterations 132
DICPCG:  Solving for p, Initial residual = 1, Final residual = 0.0934216, No Iterations 192
time step continuity errors : sum local = 6.39919e+21, global = 5.204e+20, cumulative = 5.204e+20
ExecutionTime = 0.79 s  ClockTime = 1 s
Time = 10
DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 0.0895149, No Iterations 116
DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 0.0685429, No Iterations 109
The time step continuity errors are very large as you can see. I have been through the threads related to this topic and I haven't understood yet what is causing these errors.
I toyed around the relTol as mentioned in threads like this:
But these are errors are very small in magnitude, whereas mine are on the other end of the spectrum.
What should be the source of these errors?
deepbandivadekar is offline   Reply With Quote
Old   November 14, 2017, 07:19
Deep
This is my choice of p and U solvers in the fvSolutions
solvers
    p
        solver          PCG;
    preconditioner    DIC;
        tolerance       1e-07;
        relTol          0.1;
//        smoother        GaussSeidel;
    U
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-07;
        relTol          0.1;
SIMPLE
//    nUCorrectors    2;
    nNonOrthogonalCorrectors 0;
    residualControl
      p    1e-6;
      U 1e-6;
    pRefCell 0;
    pRefValue 0;
relaxationFactors
    fields
        p               0.2;
        U               0.9;
//        k               0.9;
//        epsilon         0.9;
This is a 2D (quasi 3D) case of flow through porous medium.
Is the error related to any of these parameters ?
Old   November 14, 2017, 11:22
Default Update
Deep
Update: Decreasing relaxation factors did not help as per this thread here: simpleFoam time step continuity errors
I changed it to 0.5 for U and same (0.2) for p in fvsolution
The boundary conditions seem to be okay for this case. Nothing has changed in the output.
I don't see how this error can be resolved. Can anyone please help?
Old   November 16, 2017, 10:04
Deep
Anyone at all ? Still stuck here..
Old   November 16, 2017, 11:44
Ricky
kera is on a distinguished road
Hallo!
There are still other stuff which may lead to this error:
1) Have you checked the quality of your mesh?
2) The boundary conditions at the inlet and outlet for U and p?
Regards,
Ricky
If it is easy, then something is fishy!
kera is offline   Reply With Quote
Old   November 16, 2017, 11:56
Deep
Originally Posted by kera View Post
Hallo!
Regards,
Ricky
Thanks kera for responding.
1) Yes, with checkMesh. Also visually in paraview. Mesh is fine.
2) As suggested in the tutorial (image attached)
File Type: jpg Screenshot from 2017-11-16 16-53-24.jpg (66.9 KB, 11 views)
Old   November 16, 2017, 16:20
Jaydeep
jaydeep is on a distinguished road
There was one time I had similar error, in my case I had forgotten to scale my mesh (inch to m). Did you have any scaling operation?
Please post your case for more details
kera likes this.
jaydeep is offline   Reply With Quote
Old   November 17, 2017, 07:07
Deep
I did. But I don't see how that should cause something like this. At max it would need more number of iterations to converge. Am I right?
Old   November 17, 2017, 07:08
Deep
Inch to metre..hmm maybe. Those are inconsistent units.
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 5, 2023 23:48
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 10:08
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
