drag coeff.
Old   November 20, 2017, 07:24
Default drag coeff.
A. Min
alimea is on a distinguished road
Hi foamers
I want to simulate flow around cylinder and calculate drag coeff. with openFoam. In papers calculated Cd is 1.9 but when I compute it with openfoam that is earned 4.3!!
Re = 25 (U=1 , rho = 1 , D=1 , nu = 0.04)- simpleFoam - my mesh is OK (I think!)
Do you know why?!
Thanks
alimea is offline   Reply With Quote
Old   November 20, 2017, 07:36
sheaker's Avatar
Oskar
sheaker is on a distinguished road
It is probably because Your turbulence model assume there is fully turbulent flow in entire domain while in fact there is laminar flow in viscous sublayer. Turbulent viscous is higher than laminar viscous so drag coefficient is too high.
To prevent this You could try to use following transient turbulence model:
Langtry-Menter k-omega Shear Stress Transport (SST)
If You succeed with Your simulation could You possibly share Your case?
Have a nice day.
Sheaker
sheaker is offline   Reply With Quote
Old   November 20, 2017, 07:39
A. Min
Have a nice day.
Sheaker
Dear Oskar
Thank you for your answer. as you know my Re number is 25 and in this Re flow regime is laminar. Also I should tell you that I did my simulation similar to :
http://nbviewer.jupyter.org/github/s...m/README.ipynb
thanks
Old   November 20, 2017, 08:38
sheaker's Avatar
Oskar
I'm so sorry. I missed Your Re is 25!(I have just woke up...) I was trying to match drag coef of an airfoil that's why I assume Your case is similar.
Now when I think for a while there are some things You should ask Yourself:
- Your coefficients depends on depth of Your mesh. Is Your mesh 1meter depth?
- I'm not sure about Your nu value. You are sure?
- Your case is incompressible and Your density is set to 1 - this is right but as I remember calculation of coefficient is not the same way as in compressible case. You are sure You calculate it in right way?
I'm sorry but I can't help better.
Have a nice day.
Sheaker
Old   November 20, 2017, 08:45
A. Min
Have a nice day.
Sheaker
Thanks for your reply
1- yes, my mesh 1meter depth
2- nu is calculated using Re. Re= 25 and other parameter is 1. so n=0.04
3- I'm not sure about this! I'm using the forces code of openFoam.
however, thank you
drag, simplefoam
Difficulty in understanding Coeff. of Drag of Airfoil Mhrc Main CFD Forum 0 April 9, 2017 01:38
How to visualize lift and drag coeff frossi CFX 3 February 5, 2017 18:29
Induced drag, pressure drag, viscous drag. aleix.de.toro FLUENT 2 August 24, 2015 18:00
drag coeff to high - kOmegaSST turbulence model RugbyGandalf OpenFOAM 5 February 22, 2011 02:35
High drag coeff. estimated by Gambit+fluent M. suuri FLUENT 6 November 6, 2006 08:02
