Pressure jump wrt Flow/velocity
Old   November 29, 2017, 05:43
Default Pressure jump wrt Flow/velocity
carno
Carno is on a distinguished road
Hi Friends,
I want to give pressure jump in OF with respect to flow rate. This is basically fan curve (Pr. vs Q) which I want to enter. Based on the system resistance the flow rate through the fan will be set.
When I try to do that through cyclic BC, it takes table only wrt to time not in terms of velocity or flow. This is quite possible in other commercial tools.
Is there any workaround on this? Please help.
Thnaks
Carno
Carno is offline   Reply With Quote
Old   November 30, 2017, 04:17
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
You need to use the "fan" boundary in your pressure file:
    Fan_master
        type            fan;
        patchType       cyclic;
        jumpTable       table
        (// PressureJump vs mean velocity format: ( "mean velocity" "pressure jump")
            (  1   250)
            ( 2   200 )
            ( 4  150 )
            ( 6.5   100 )
            ( 7.5   50 )
            ( 8  0.01 )
        outOfBounds clamp;
        value           $internalField;
    Fan_slave
        type            fan;
        patchType       cyclic;
Fan direction is in the normal direction of the master patch.
Cheers,
Tom
tomf is offline   Reply With Quote
Old   December 1, 2017, 07:36
carno
Thanks Tom,
I will check that.
But in that, how Openfoam will know that the table is of velocity vs deltaP?
Thanks Again...
Best regards,
Carno
Old   December 1, 2017, 07:45
Tom Fahner
Check the source code of the fan boundary condition.
Regards,
Tom
Old   December 1, 2017, 08:11
carno
Originally Posted by tomf View Post
Regards,
Tom
Thanks for the reply Tom. I will look into the code as suggested.
I apologize for asking again. Why did you comment the line
Thanks again
Old   December 1, 2017, 08:15
Tom Fahner
Hi Carno
I did it just to give you this hint. I originally did it for myself.
It was not meant to give you confusion, to the contrary actually.
Regards,
Tom
Old   January 4, 2018, 07:25
carno
My Problem is solved thanks.
Now I have different question about the direction of it.
I have used following script in p file.
fan_master
	type            fan;
	patchType 	cyclic;
	f List<scalar>    3(3 3 -2);
	value uniform 0;
fan_slave
	type            fan;
	patchType 	cyclic;
	value uniform 0;
How to set the direction of the flow? In other words how to reverse the direction if required?
If the flow happens from master to slave, how to identify which side is the master and slave?
Thanks again..
Old   January 4, 2018, 10:33
Tom Fahner
It depends on the orientation of the master patch. If you flip it (the normal direction), the direction of the fan will change. I am just not sure how to do it in OpenFOAM directly. I prepare my cases using ANSA, where I can easily flip the orientation of such a patch. Probably the slave will have to be flipped as well. I think that the master is always the first entry in constant/polyMesh/boundary.
Regards,
Tom
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 05:35
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 13:04
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC Endel OpenFOAM Running, Solving & CFD 3 September 11, 2014 16:29
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
How to control pressure jump in a fan? Ana FLUENT 1 April 8, 2006 08:25
