Body force in fvOptions in interFoam
Old   January 27, 2022, 03:55
Default Body force in fvOptions in interFoam
Geb1313 is on a distinguished road
Hello Foamers,
I am thinking to model a dam break using interFoam solver. The dam has a rectangular shape as most of the dam break tutorials, but with a solid rectangular block(constant density) on the top of it. As per my understanding the impact of the block on cells beneath it is a pressure force of magnitude density*gravity* depth of the block acting on the vertical surface area(xy plane) of the cells.
Now my question is how can add this force as a coded source.
My first thought was: providing the force as P = (0 0 rho*g*h) and to be included into the momentum equation it should be force per unit volume. I was lost after this. The actual dimension of the force P is dimension of pressure. I have to change it to weight (force) by: F = P &mesh.sf(). And dividing F by mesh.V() provides the dimension required. However, I am not sure if this is possible.
Any recommendation please?
Geb1313 is offline   Reply With Quote
Old   June 23, 2022, 13:39
Mahmoud
Mahmoud Abbaszadeh is on a distinguished road
Originally Posted by Geb1313 View Post
Hello Foamers,
Hi
Have you got an answer for this problem?
Mahmoud Abbaszadeh is offline   Reply With Quote
fvoptions, interfoam
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" ds4719 Main CFD Forum 14 February 18, 2022 18:05
Different calc for lift between: force coefficient report and 6-DOF body force report hxax STAR-CCM+ 3 January 16, 2020 10:08
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 11:12
Implementing surface force in interFoam traens OpenFOAM Programming & Development 2 July 17, 2017 04:14
how to include body force in cfx selvam R.P CFX 4 November 25, 2005 04:01
