January 27, 2022, 03:55 |
Body force in fvOptions in interFoam
Rep Power: 6 |
Hello Foamers,
I am thinking to model a dam break using interFoam solver. The dam has a rectangular shape as most of the dam break tutorials, but with a solid rectangular block(constant density) on the top of it. As per my understanding the impact of the block on cells beneath it is a pressure force of magnitude density*gravity* depth of the block acting on the vertical surface area(xy plane) of the cells. Now my question is how can add this force as a coded source. My first thought was: providing the force as P = (0 0 rho*g*h) and to be included into the momentum equation it should be force per unit volume. I was lost after this. The actual dimension of the force P is dimension of pressure. I have to change it to weight (force) by: F = P &mesh.sf(). And dividing F by mesh.V() provides the dimension required. However, I am not sure if this is possible. Any recommendation please? |
June 23, 2022, 13:39 |
#2 | |
Mahmoud
Rep Power: 5 |
Hi Have you got an answer for this problem? |
fvoptions, interfoam |
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" | ds4719 | Main CFD Forum | 14 | February 18, 2022 18:05 |
Different calc for lift between: force coefficient report and 6-DOF body force report | hxax | STAR-CCM+ | 3 | January 16, 2020 10:08 |
ActuatorDiskExplicitForce in OF2.1. Help | be_inspired | OpenFOAM Programming & Development | 10 | September 14, 2018 11:12 |
Implementing surface force in interFoam | traens | OpenFOAM Programming & Development | 2 | July 17, 2017 04:14 |
how to include body force in cfx | selvam R.P | CFX | 4 | November 25, 2005 04:01 |
