fvOptions -call value from different region
Old   December 8, 2017, 09:27
Default fvOptions -call value from different region
TobiF is on a distinguished road
Hello everybody,
I'm working on heatTransfer simulations in which I want to define the heater-power depending on a sensor temperature that is measured in a different region.
(Working with chtMultiRegionFoam and the codedSource in fvOptions...)
Therefore I'm calculating the mean-temperature in the sensor but I'm not able to call this value in the heater-region.
If the sensor is placed inside the heater-domain, than everything is working perfectly.
Is there a possibility to call such a value or to transfer it into other region, or do I have to create an output-file?
Thanks you!
Tobi
TobiF is offline   Reply With Quote
Maximum number of iterations exceeded chtmultiregionsimpleFoam Moncef OpenFOAM Running, Solving & CFD 28 July 13, 2020 14:26
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 05:07
Taking too much for run Grimoli OpenFOAM Running, Solving & CFD 5 November 26, 2013 20:07
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
