December 20, 2017, 09:35 |
oversetmesh with 6 DOF in v1706
shota sasaki
Rep Power: 8 |
Hi, I am new here.
I started to use OpenFoam v1706 one month ago in order to simulate the movement of the 3D object under the force of the fluid. I tried it using pimpleDyMFoam but mesh deformation is too big to simulate. So now I am working on it by using oversetmesh function. I ran some tutorials about oversetmesh but I could not use oversetmesh(overPimpleDyMFoam) with 6DOF. How can I use oversetmesh with 6DOF? |
December 21, 2017, 04:21 |
Hi, look at this tutorial case:
$FOAM_TUTORIALS/multiphase/overInterDyMFoam/floatingBody Regards, Tom |
December 21, 2017, 16:44 |
shota sasaki
Rep Power: 8 |
Hi, Thank you for reply.
I could not run the tutorial due to the error below when I use overInterDyMFoam. —————————————————————————————————- —> FOAM FATAL IO ERROR: This code should not be executed by someone with administrator rights due to security reasons. (it writes a shared library which then gets loaded using dlopen) file; /home/Desktop/openfoam-plus/tutorials/floatingBody/background/constant/dynamicMeshDict.sixDofRigidBodyMotionCoeffs from line 30 to line 30. From function static void Foam::dynamicCode::checkSecurity(const char*, const Foam::dictionary&) in filedb/dynamicLibrary/dynamicCode/dynamicCode.C at line 65. —————————————————————————————————- I use the Openfoam v1706 in docker, how can I avoid this error? It seems that I can start docker as superuser only. and I would like to simulate the movement of a complicated shape object placed in the water flow. Is it possible to use the snappyHexMesh to make case of oversetmesh, and give a uniform flow in overInterDyMFoam? |
December 21, 2017, 17:16 |
I would not know how to help you with this. Maybe someone else with more experience on Docker/OpenFOAM on Windows can help you with this. It souns like a configuration error, but as I only run natively in Linux I can not help you.
Best of luck! Regards, Tom |
June 12, 2020, 11:21 |
#5 | |
TAKILT said
Rep Power: 6 |
HI, I want to do the same as you, have you managed to use 6Dof with Overset??? best regards |
6dof, overpimpledymfoam, oversetmesh |
Six DoF - Overset in OpenFOAM | ddemiroguzhan | OpenFOAM Running, Solving & CFD | 1 | January 24, 2019 05:36 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
The concept of DOF in fluid mechanics and CFD | bearcat | Main CFD Forum | 8 | May 27, 2007 18:02 |
help required in using six dof solver in fluent | Shah | FLUENT | 1 | February 25, 2006 11:31 |
Six dof UDF | Dr. John Anttonen | FLUENT | 0 | February 22, 2002 14:47 |
