December 31, 2017, 10:37 |
Heating of a building
Rep Power: 8 |
Hey guys I have started working with OpenFOAM 3weeks ago and need some tips for setting up my case.
I am looking at a building with a heat source (in kW) and want to simulate the heating of the room. I just want to see the air temperature nothing else. I would like to set a start temperature (for example 293K) and want to see the temperature 1, 2 or 3 hours later. I already checked some tutorials but didn't find one which has a heat source given in W or J. The hotRoom tutorial seems to work with temperature and doesn't really help me. So my questions are: 1. How do I set up a start Temperature and where? (T-file?) 2. How and where do I define the heat source? 3. How do I calculate the temperature at 1,2 or 3 hours? (by using calculated BC in T-file or is there another way?) 4. I would use buoyantBoussinesqPimpleFoam solver. Or should I try chtMultiRegionFoam? If you need more information or think that I've forgot something just let me know. Thank you in advance and happy new year everyone. |
December 31, 2017, 11:25 |
Uwe Pilz
Rep Power: 15 |
I used buoyantBoussinesqPimpleFoam with some success. I did not find a boundary condition that you indent to use. I recommend to use the temperature b.c. and calculate the heat production form the result. In a few steps you should have found a temperature which fulfills the heat production.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
December 31, 2017, 11:50 |
Rep Power: 20 |
buoyantBoussinesqPimpleFoam and chtMultiRegionFoam are essentially identical in recent OF versions since you can choose the Boussinesq assumtion in the thermoPhysicalProperties file. If you need different regions coupled cht is the way to go. E.g If you want to include conduction through the walls and can't treat them as boundary condtions. To answer your questions:
The initial temperature is set in the 0/T file. You can set a uniform value to the entire volume or use the setFields utility to vary it in space. You can add a volumetric heat source via fvOption Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: dev | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object fvOptions; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // options { energySource { type scalarSemiImplicitSource; selectionMode all; volumeMode specific; injectionRateSuSp { h (1.5e6 0); } } } // ************************************************************************* // Code:
heat { type externalWallHeatFluxTemperature; kappaMethod fluidThermo; mode flux; // flux for W/m² or power for W q uniform 100; // 100 W/m² Q uniform 100; // 100 W value $internalField; // initial temperature } |
January 1, 2018, 06:54 |
Rep Power: 8 |
Thanks a lot guys
I will try to setup the case within the next days and will tell you if it worked out or if I need more help. |
January 8, 2018, 04:41 |
#5 | |
Rep Power: 8 |
I am still trying to figure out how to add a heat source. I am trying to add one to the floor of the hot room tutorial case, just to understand it. Another question: Is it possible to set up a heat source in W/m² by using fvOptions? Edit: is there any tutorial case with a heat source given in W or W/m²? checked all heatTransfer tutorials but didn't find what I was looking for Last edited by Eko; January 8, 2018 at 09:48. |
January 10, 2018, 04:52 |
Rep Power: 8 |
One more question. If I put a solid, for example a cube into the room as heat source. So the air in the room is heaten up by this cube. Does this already count as multiregion? Do I have to use chtMultiRegionFoam in this case or can buoyantBoussinesqPimpleFoam solve this?
January 10, 2018, 06:47 |
Uwe Pilz
Rep Power: 15 |
May be you can find boundary conditions which are suitable for what happens with the cube. If you want to know the temperature distribution in the cube I see two ways
- multi region or if the heat capacity of the room is mauch larger than the one of the cube - Define the cube as wall and read the temperature distribution of the wall. Make a different simulation with only the cube and set this temperature as b.c.
January 10, 2018, 07:05 |
#8 | |
Rep Power: 8 |
I'm currently setting up a more difficult case with chtMultiRegionFoam and till now it's going well. Just a lot more work to do with the CAD, meshing, setting up files compared to buoyant tasks. Last edited by Eko; January 10, 2018 at 08:08. |
[OpenFOAM.org] OpenFOAM 2.3.0 on CentOS 6.5 | entropies | OpenFOAM Installation | 33 | January 4, 2017 05:01 |
[foam-extend.org] Error compiling OpenFOAM-1.6-ext | Canesin | OpenFOAM Installation | 137 | January 20, 2016 14:56 |
Tool for heating energy and temperature simulation in building | badertscher | Main CFD Forum | 0 | June 9, 2013 13:30 |
Paraview Compiling Error (OpenFOAM 2.1.x + openSUSE 12.2) | sfigato | OpenFOAM Installation | 22 | January 31, 2013 10:16 |
Compilation error OF1.5-dev on Suse10.3 | darenyang | OpenFOAM Installation | 0 | April 29, 2009 04:55 |
