Compiling problem(EXE_INC)!!!!
Old   January 11, 2018, 07:12
Post Compiling problem(EXE_INC)!!!!
Jung da yoon
kane is on a distinguished road
Greeting All!!
I have tried to make my customized solver using buoyantSimplefoam.
So I copied directory(src/thermophysicalModels/radiation) and solver files(buoyantSimplefoam in) root.
And then I pasted them into my own directory(/home/OpenFOAM/dayoon15-5.0/src).
Next I modified codes in file(/home/OpenFOAM/dayoon15-5.0/src/radiation/radiationModel/P1).
But i had to modify 'EXE_INC codes' in Make/options to compile my customized solver. Because i modified codes in file (/home/OpenFOAM/dayoon15-5.0/src/radiation/radiationModel/P1).
First, it is original codes(Make/options)
EXE_INC = \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/sampling/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude \
    -I$(LIB_SRC)/transportModels/compressible/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/radiation/lnInclude \
    -I$(LIB_SRC)/TurbulenceModels/turbulenceModels/lnInclude \
    -I$(LIB_SRC)/TurbulenceModels/compressible/lnInclude
EXE_LIBS = \
    -lfiniteVolume \
    -lfvOptions \
    -lsampling \
    -lmeshTools \
    -lcompressibleTransportModels \
    -lfluidThermophysicalModels \
    -lspecie \
    -lradiationModels \
    -lturbulenceModels \
    -lcompressibleTurbulenceModels \
    -lmeshTools
I feel that it is necessary to modify the code,-I$(LIB_SRC)/thermophysicalModels/radiation/lnInclude \
What should I do??
How can i link files in my storage space??
kane is offline   Reply With Quote
[OpenFOAM.org] Compiling OpenFOAM 5.0 on the Titan Supercomputer wildfire230 OpenFOAM Installation 20 May 6, 2020 07:30
Getting error both interpreting and compiling serene6390 Fluent UDF and Scheme Programming 1 October 27, 2017 00:49
All files present. but solver not compiling saddy OpenFOAM Programming & Development 1 July 29, 2017 09:50
[OpenFOAM.org] Trouble Compiling OpenFOAM-dev using Intel Compiler 15 for use on Xeon Phi foamer123 OpenFOAM Installation 9 August 20, 2015 14:03
Help with KIVA4 source code compiling geothokar Main CFD Forum 0 September 3, 2010 05:40
