Cornering Flow Boundary Conditions (OpenFoam) |
February 1, 2018, 08:49 |
Rep Power: 8 |
Hi, I'm interested in examining the aerodynamic effects of cornering flow on an FSAE car. After searching online, I came up to the conclusion that this (Fig.1) type of mesh would be the most beneficial for the simulation.
Fig.1 The issue now is how can someone assign two boundary conditions on the same field of a mesh for use in OpenFoam? As you can see, there is one "inlet" bc and one "outlet" bc on the same field. Any thoughts on how it can be done? Any other tip on cornering flow simulations would be greatly appreciated! Thanks in advance! |
February 1, 2018, 11:35 |
Uwe Pilz
Rep Power: 15 |
An easy way is to divide the area in strips. For every Strip you can set the b.c. you need.
Anothe way ist to use curved boundary and to have only an inlet and an outlet and two walls.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
February 1, 2018, 18:43 |
#3 | ||
Rep Power: 8 |
February 2, 2018, 00:27 |
Uwe Pilz
Rep Power: 15 |
This is simple : Create three strips with blockmesh, and define eight boundary areas form them.
February 2, 2018, 08:59 |
Rep Power: 8 |
February 2, 2018, 12:21 |
Uwe Pilz
Rep Power: 15 |
I recommend strongly to look at the examples which are delivered with OpenFoam. I cannot describe the usage of blockMesh with a few words.
OF has a manual which should be included in the installation. It describes the usage of blockMesh.
February 2, 2018, 14:57 |
Rep Power: 8 |
Problem solved, I misunderstood the meaning of the word "strip".
March 16, 2023, 08:42 |
#8 | |
Rep Power: 4 |
I know this is a really old case but it would mean a lot if you could help me with my question. I am trying to simulate this exact case, my idea is to create a rectangular domain with the the inlets and outlets as indicated in the picture and then rotate the domain around an external point. But I am not exactly sure how that can be done, is this possible by using MRF or is there another Openfoam function that I have to use to do this. Best, Amirmohammad |
March 17, 2023, 02:44 |
#9 |
Uwe Pilz
Rep Power: 15 |
I don't know any tool which rotates a mesh. But it may be, there is one.
I recommend modifying the blockmesh file itself, or may be easier, generate it from a small program. This program may have all parameters as input and you could automate your simulations.
March 17, 2023, 03:44 |
#10 | |
Yann
Rep Power: 26 |
Maybe you could use SRF for this. Have a look at SRFSimpleFoam/SFRPimpleFoam. Regards, Yann |
March 23, 2023, 10:24 |
#11 |
Rep Power: 4 |
Thanks for your message Uwe,
I also think it would be best to mesh with another software and bringing it to OpenFOAM. Best, Amirmohammad |
March 23, 2023, 10:25 |
#12 |
Rep Power: 4 |
Thanks Yann,
After reading the relevant documents, I think this is what I have been searching for. Best, Amirmohammad |
3D Windturbine simulation in SU2 | k.vimalakanthan | SU2 | 15 | October 12, 2023 05:53 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
Boundary conditions for flow in nozzle | kgevers | FLUENT | 0 | July 26, 2015 12:46 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
