pressure on facades with simpleFoam
Old   March 14, 2018, 10:05
Default pressure on facades with simpleFoam
stergiani
stergiani is on a distinguished road
Hei,
I have done some pressure measurements in two buildings and I want to compare my simulation with the measurements.
I could only measure differential pressure between windward and leeward facade, so I was actually wondering how can I get the same from the simulation. Can i just get the difference between windward and leeward side from OpenFOAM? I know that on incompressible flow I get the p/rho and that I can also add the reference pressure, but the difference would still be the same.
So, when I have a positive pressure on the windward and a negative on the leeward, is it correct to assume that the differential pressure (to compare with the measured differential) can be calculated by substracting one from the other?
Any advice? Thanks
Stergiani
stergiani is offline   Reply With Quote
Getting hydrostatic pressure in a vertical box using simpleFOAM maxou1993 OpenFOAM Running, Solving & CFD 3 June 13, 2022 05:02
interFoam (HELYX-OS) pressure boundary conditions SFr OpenFOAM Running, Solving & CFD 8 June 23, 2016 16:36
CFX Solver stopped with error when requested for backup during solver running Mfaizan CFX 40 May 13, 2016 06:50
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC Endel OpenFOAM Running, Solving & CFD 3 September 11, 2014 16:29
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
