printstack error caused by subsetMesh error
Old   March 29, 2018, 01:29
Default printstack error caused by subsetMesh error
jiahui_93 is on a distinguished road
Hi everyone, I faced printstack error when running pimpleFoam. I saw some posts said that it may be caused by division of 0 but I didn't set 0 value for any fields except nut.
Attached is link of my input files.
https://www.dropbox.com/sh/ea5auq83u...9ZzX7N7Sa?dl=0
This probably caused by bad mesh. So I checkMesh but the result is ok and last time step showed fail 1 mesh. However, foamToVTK showed that my cellSets, eg: carExtCS (a hollow box) is ok before that. But it became inappropriate after subSet Mesh. Attached picture is cellSet carExtCS before and subsetMesh
May I get some help on this? How should i subsetMesh to delete unwanted region to make a hollow space within my domain? Thanks a lot for your time to read through this
Below is the output when run simulation
https://www.dropbox.com/s/xu4hljpr7l...blockMesh?dl=0
jiahui_93 is offline   Reply With Quote
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
