Odd snappyHex meshing error, can't find issue |
April 4, 2018, 13:47 |
Rob
Rep Power: 8 |
Can anyone help me understand the cause for this error, please?
I can't figure out why these lib files are shown in the error output. I've searched various pieces of the message and found nothing relating to this issue I'm seeing. [0] #0 Foam::error:rintStack(Foam::Ostream&) at ??:? [0] #1 Foam::sigFpe::sigHandler(int) at ??:? [0] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" [0] #3 Foam::combineFaces::regioniseFaces(double, int, Foam::List<int> const&, Foam::Map<int>&) const at ??:? [0] #4 Foam::combineFaces::getMergeSets(double, double, Foam::HashSet<int, Foam::Hash<int> > const&) const at ??:? [0] #5 Foam::meshRefinement::mergePatchFacesUndo(double, double, Foam::List<int> const&, Foam::dictionary const&, Foam::List<int> const&) at ??:? [0] #6 Foam::snappySnapDriver::doSnap(Foam::dictionary const&, Foam::dictionary const&, double, double, Foam::snapParameters const&) at ??:? [0] #7 ? at ??:? [0] #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [0] #9 ? at ??:? [CFDsolver:10964] *** Process received signal *** [CFDsolver:10964] Signal: Floating point exception (8) [CFDsolver:10964] Signal code: (-6) [CFDsolver:10964] Failing at address: 0x3e800002ad4 [CFDsolver:10964] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7f8c654584b0] [CFDsolver:10964] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7f8c65458428] [CFDsolver:10964] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7f8c654584b0] [CFDsolver:10964] [ 3] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libdynamicMesh.so(_ZNK4Foam12combineFaces14regioni seFacesEdiRKNS_4ListIiEERNS_3MapIiEE+0x1e3)[0x7f8c67434bd3] [CFDsolver:10964] [ 4] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libdynamicMesh.so(_ZNK4Foam12combineFaces12getMerg eSetsEddRKNS_7HashSetIiNS_4HashIiEEEE+0x334)[0x7f8c67437114] [CFDsolver:10964] [ 5] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libsnappyHexMesh.so(_ZN4Foam14meshRefinement19merg ePatchFacesUndoEddRKNS_4ListIiEERKNS_10dictionaryE S4_+0x195)[0x7f8c66f90575] [CFDsolver:10964] [ 6] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libsnappyHexMesh.so(_ZN4Foam16snappySnapDriver6doS napERKNS_10dictionaryES3_ddRKNS_14snapParametersE+ 0x21f6)[0x7f8c66ec5826] [CFDsolver:10964] [ 7] snappyHexMesh[0x41767d] [CFDsolver:10964] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7f8c65443830] [CFDsolver:10964] [ 9] snappyHexMesh[0x4187f9] [CFDsolver:10964] *** End of error message *** |
April 4, 2018, 16:31 |
Rob
Rep Power: 8 |
I apologize, I intended to put this in the meshing forum.
Regardless, I've tinkered with mesQualityDict and magically things work now. I am unsure how my changes effected the issue, which is very frustrating. |
CFX-Pre problem, pls help!!! | cth_yao | CFX | 0 | February 17, 2012 00:52 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 12:38 |
Problem Building OF on Centos cluster (no admin rights) | CKH | OpenFOAM Installation | 5 | November 13, 2011 06:32 |
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 05:22 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
