Problem about Absorption coefficient for each mesh separately
Old   April 10, 2018, 11:15
Post Problem about Absorption coefficient for each mesh separately
Jung da yoon
kane is on a distinguished road
Hello!!
I'm trying to set absorption coefficient, a for each mesh separately.
Now, I use a constant absorption coefficient.
|  \\    /   O peration     | Version:  2.2.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      radiationProperties;
radiation on;
radiationModel  fvDOM;
fvDOMCoeffs
    nPhi    3;         // azimuthal angles in PI/2 on X-Y.(from Y to X)
    nTheta  6;          // polar angles in PI (from Z to X-Y plane)
    convergence 1e-6;   // convergence criteria for radiation iteration
    maxIter 1000;         // maximum number of iterations
// Number of flow iterations per radiation iteration
solverFreq 1;
absorptionEmissionModel constantAbsorptionEmission;
constantAbsorptionEmissionCoeffs
   absorptivity    absorptivity    [ 0 -1 0 0 0 0 0 ]  1;
   emissivity      emissivity      [ 0 -1 0 0 0 0 0 ]  1;
   E               E               [ 1 -1 -3 0 0 0 0 ] 0;
scatterModel    none;
sootModel       none;
But I don't want to use constant absorptivity.
So I will make BC for absorption coefficient(a) and set the coefficient for each mesh.
But I don't know what should I do.
Does anyone know how to solve this problem?
And any case for this problem will be fine.
Best regards.
kane is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Mesh is doing some problem prwl120 FLUENT 2 May 21, 2015 14:05
[ICEM] problem in mesh output mehrzad ANSYS Meshing & Geometry 2 December 10, 2014 18:07
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
