PatchInjection crashes in parallel
Old   August 12, 2014, 08:54
Default PatchInjection crashes in parallel
Marco Macchi
marcomacchi is on a distinguished road
Dear all,
I am simulating a flow with the lagrangian solver sprayFoam. If I inject particles with the coneInjection model I can run in parallel my case, but if I use the patchInjection model it crashed at the beginning, even though it works in serial. I thought that the problem was that my domain was cut exactly where the injector was but I verified that is not. Does someone have the same problem of know how to fix this?
Thanks,
Marco
marcomacchi is offline   Reply With Quote
Old   March 7, 2016, 09:16
Freedom
wenxu is on a distinguished road
I also encounter the same problem. Have you solved your problem? Could you tell us? Thank you very much!!!
Best regards,
Xu
wenxu is offline   Reply With Quote
Old   April 23, 2018, 11:21
Scram_1 is on a distinguished road
Hello everyone,
Has anyone solved this issue? Even I'm facing a similar issue in that, my case runs in serial mode but crashes after a few iterations in parallel when the preferred injection mode is patchInjection.
Best,
Scram_1
Scram_1 is offline   Reply With Quote
parallel, patch, sprayfoam
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 18:45
Parallel runs with sonicDyMFoam crashes (works fine with sonicFoam) jnilsson OpenFOAM Running, Solving & CFD 0 March 9, 2012 06:45
SnappyHexMesh OF-1.6-ext crashes on a parallel run norman1981 OpenFOAM Bugs 5 December 7, 2011 12:48
Moving mesh crashes in parallel (1.5-dev) jploz OpenFOAM Programming & Development 8 October 21, 2009 17:22
Solver crashes (PVM parallel) Marco Müller CFX 2 February 4, 2009 02:51
