Modifying the laplacian operator
Like Tree5Likes
Old   June 10, 2009, 14:45
Default Modifying the laplacian operator
Michael Lawson
mlawson is on a distinguished road
Hi everyone,
I would like to modify the laplacian so the derivative is only calculated in one direction - that is I would like to compute only d^2T/dx^2 and not d^2T/dx^2 + d^2T/dy^2 + d^2T/dz^2
Then I want to solve a system of equations using this modified laplacian. I tried to do this by dotting the result of the laplacian operator with a unit normal vector in the x-direction. A simple example would be:
solve
fvm::ddt(T)
- fvm::laplacian(DT, T) & xDir // where xDir is a dimentionedVector with the units [0 1 -1 0 0 0 0] (1 0 0)
Unfortunately, I get the following error when trying to compile my solver.
1dScalarTransportFoam.C: In function ‘int main(int, char**)’:
1dScalarTransportFoam.C:67: error: no match for ‘operator&’ in ‘Foam:perator-(const Foam::tmp<Foam::fvMatrix<Type> >&, const Foam::tmp<Foam::fvMatrix<Type> >&) [with Type = double](((const Foam::tmp<Foam::fvMatrix<double> >&)((const Foam::tmp<Foam::fvMatrix<double> >*)(& Foam::fvm::laplacian(const Foam::dimensioned<Type2>&, Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) [with Type = double, GType = double](((Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&)(& T))))))) & xDir’
I assume I get this error because the & operator is not defined for a fvScalarMatrix.
Does anyone know a method modifying the laplacian operator so that the derivative is only calculated in one direction?
-Mike
missios likes this.
mlawson is offline   Reply With Quote
Old   August 3, 2011, 16:27
Mieszko Młody
ziemowitzima is on a distinguished road
I am trying to do the same thing.
Did you manage to do this ?
Method you described is wrong, because laplacian(DT,T) is not a vector , but scalar:
Txx + Tyy + Tzz, so you cant make dot product operation for scalar and vector...
I did it in explicit way, but this not the best way...
If you have some updates how to solve this problem, pleas let me know.
best
-ZM
missios likes this.
ziemowitzima is offline   Reply With Quote
Old   August 3, 2011, 16:54
Michael Lawson
You are correct the result of the laplacian operator is a scalar in this case. What should have asked is, is there a way to dot the laplacian operator itself with a unit vector before it is applied to the variable T (i.e (d/dx^2 + d/dy^2 + d/dz^2) dot (1 0 0) * T).
Either way, I never did solve this problem in a robust way. I ended up tricking the solver into only computing diffusion in one direction by making my two dimensional domain very long in one of the non-empty directions, the y-dir in my case, so the d/dy^2 term was negligible with respect to the d/dx^2 term. I know this is not a good way to solve the problem, but it ended up working for the specific case I was working on.
Good luck and please let me know if you find a solution to the problem.
-Mike
Old   August 3, 2011, 17:23
Mieszko Młody
in explicit way u can do this like that:
volVectorField gradT=fvc::grad(T);
volScalarField gradTx = gradT & vector(1,0,0);
volScalarField Tx = gradT.component(0); // T_x
volVectorField gradT2 = fvc::grad(Tx); // (T_xx, T_xy)
volScalarField Txx = gradT2.component(0); // T_xx
Old   August 4, 2011, 03:32
akidess's Avatar
Anton Kidess
Michael, it sounds like you want anisotropic diffusion - why not just pass a diffusion coefficient tensor to laplacian instead of a scalar? I don't think you need any modifications to the code to do that (but I haven't tried it myself).
Old   August 4, 2011, 10:32
Michael Lawson
Hi Anton,
Mathematically that makes sense, but I'm unsure how to convert the scalar field T into a tensor in OpenFOAM. Do you have an idean about how this would be done?
-Mike
Old   August 4, 2011, 10:49
akidess's Avatar
Anton Kidess
T stays a scalar field, you only have to change the diffusion coefficient into a tensor (you wouldn't do anything else on pen and paper). Redefine DT from dimensionedScalar to dimensionedTensor (see e.g. http://www.foamcfd.org/Nabla/guides/...sGuidese5.html) and recompile.
Elham and dduque like this.
Old   August 4, 2011, 12:13
Mieszko Młody
Hi Akidess,
Thanks for your suggestion.
It works just as it should.
Human being is learning all its life...
To Mlawson:
x - direction diffusion:
DTe DTe [ 0 2 -1 0 0 0 0 ] (3e-02 0 0 0 0 0 0 0 0 );
x,y and - directions diffusion:
DTe DTe [ 0 2 -1 0 0 0 0 ] (3e-02 0 0 0 3e-02 0 0 0 3e-02 );
Thanks again!
Old   September 7, 2011, 11:51
Matthias Voß
mvoss is on a distinguished road
hey there.
could anybody please give me a hint on where to find some sort of documentation for a part of the FSI-solver (icoFSIFoam??) like mentioned above. i am espacially interessted in how the pde´s have been derived for the solid/stress part.
e.g. fvm::laplacian (2*mu, + lambda, Usolid, "laplacian (DU,U)")
what is that third part good for? I wasn´t able to get any doc. for a third part in laplacian(..).
Is this some sort of comment??
Thanks in advance,
neewbie
mvoss is offline   Reply With Quote
Old   September 7, 2011, 12:05
Mieszko Młody
Third part "laplacian(DU,U)" is just needed for fvScheme file, where laplacian(DU,U) is defined. Here it just says that variable DU = 2*mu + lambda.
ZMM
Old   September 7, 2011, 12:06
Matthias Voß
okay.
found it. i guess.
it´s a label for that part of the eq. to hook it up with the schemes in fvSchemes.
Old   September 7, 2011, 12:30
Mieszko Młody
I think that all needed information you can find in the solver description:l
inear-elastic, small-strain deformation of a solid body, with optional thermal
diffusion and thermal stresses.
For example in solver solidDisplacementFoamfact there are only two PDE solved (I dont know where FSIsolver is):
fvm::ddt(T) == fvm::laplacian(DT, T)
and
fvm::d2dt2(D)
fvm::laplacian(2*mu + lambda, D, "laplacian(DD,D)")
+ divSigmaExp
first equation is just standart heat equation,
second equation is just linear-elastic equation with optional thermat stress (+ divSigmaExp) influence (calculated by solving first equation).
This are standart equations so they derivation can be easly found in basic PDE books, or online:
http://en.wikipedia.org/wiki/Linear_elasticity
ZMM
if (thermalStress)
Old   May 19, 2017, 10:35
Xinguang Wang
JasonWang3 is on a distinguished road
I still confused after reading all the thread. I need to separate Txx, Tyy and Tzz as mentioned.
Is there anyone give some example to do it?
Thanks a lot.
JasonWang3 is offline   Reply With Quote
Old   May 19, 2017, 13:43
Mieszko Młody
Hi Xinguang,
What do you need exactly ?
Can you explain it with more details ?
best
ZMM
Old   May 20, 2017, 08:00
Xinguang Wang
hi ZMM
I want to calculate the second derivatives of a scalar field such as Temperature separately. For example, d^2T/d^2x, d^2T/d^2y and d^2T/d^2z, and then these three terms sum up as d^2T/d^2x + d^2T/d^2y + d^2T/d^2z = laplacian(T). I need to use each term for the calculation.
Many thanks for your reply.
Jaosn
Old   May 20, 2017, 08:22
Xinguang Wang
I also tried to use grad(grad) to calculate d^2T/d^2x d^2T/d^2y d^2T/d^2z , but when I add up these three terms, it's not equal to laplacian(T)
Old   May 20, 2017, 10:16
Mieszko Młody
Laplacian does not equal grad(grad),
the true statment is:
\nu\nabla^2(T) = \nabla\cdot(\nu\nabla(T))
it OF reads:
Laplacian(T) = div(grad(T))
so you could:
gradT = grad(T)
gradT.component(1)=0
gradT.component(2)=0
T_xx = div(gradT)
gradT = grad(T)
gradT.component(0)=0
T_yy = div(gradT)
gradT = grad(T)
T_zz = div(gradT)
OR:
you could do as it is explained above:
and define the diffusivity coeff as a tensor:
for x - direction diffusion only:
DTx DTx [ 0 2 -1 0 0 0 0 ] (1 0 0 0 0 0 0 0 0 );
in the code:
T_xx=fvc::Laplacian(DTx,T)
for y - direction diffusion only:
DTy DTy [ 0 2 -1 0 0 0 0 ] (0 0 0 1 0 0 0 0 0 );
in the code:
T_yy=fvc::Laplacian(DTy,T)
for z - direction diffusion only:
DTz DTz [ 0 2 -1 0 0 0 0 ] (0 0 0 0 0 0 1 0 0 );
in the code:
T_zz=fvc::Laplacian(DTz,T)
missios likes this.
Old   May 21, 2017, 07:00
Xinguang Wang
In my code Ux is a scalar field denotes the streamwise flow velocity.
const volScalarField du2dy2=fvc::laplacian(Eiy,Ux);
where Eiy is (0,0,0,0,1,0,0,0,0)
const volVectorField gradUx=fvc::grad(Ux);
const volScalarField dudy=gradUx.component(vector::Y);
const volVectorField graddudy=fvc::grad(dudy);
const volScalarField divgradUx=fvc::div(gradUx);
(for 2D flat plate flow dudx is very small)
when I compare:
term1= du2dy2
term2=graddudy.component(vector::Y)
term3=divgradUx
term2=term3(nearly the same), but term1 is not equal to term2 or term3 (30% less)
In fvSchemes, the default scheme are all Gauss linear.
Do I miss something to make such difference happens?
Old   May 21, 2017, 08:15
Mieszko Młody
in your case :
term3 = Ux_xx + Uy_yy + Ux_yz,
so it wont be same as term1,
to have ti equal to term1, you should first:
gradUx.component(vector::X) = 0;
gradUx.component(vector::Z) = 0;
then you would have:
gradUx = (0,Ux_y,0),
an then applying:
you wpould have:
(_x,_y,_z)*(0,Ux_y,0) = Ux_yy
and term3 sould be same as term1
I am not sure about term2.
Old   July 11, 2018, 04:57
Elham
Elham is on a distinguished road
Dear Foamers,
In a multiphase fluid type, I have the following form of TEqn
    fvScalarMatrix TEqn
          fvm::ddt(T)
        + fvm::div(phi,T)
        - Foam::fvm::laplacian( k/rhoCp , T)
    TEqn.relax();
        solve
            TEqn
            fvc::ddt(p)*(1/rhoCp)
            +Foam::fvc::laplacian( D23*T , XV)
where XV is vapor mass fraction as following:
rhogp= (rho2*limitedAlpha2+rho3*limitedAlpha3)/(limitedAlpha2+limitedAlpha3);
XV= rho2/rhogp
with the above equation I got too unbounded alpha fields at very first step .If I manipulate TEqn as the following:
fvScalarMatrix TEqn
          fvm::ddt(T)
        + fvm::div(phi,T)
        - Foam::fvm::laplacian( D23*T , XV)
    TEqn.relax();
        solve
            TEqn
It will blow up at the first time step with the following error:
gradientInternalCoeficients cannot be called for a calculatedFvPatchField
I will apprciate any hint for fixing.
Cheers,
Elham
Elham is offline   Reply With Quote
Elementwise multiplication operator johndeas OpenFOAM Running, Solving & CFD 3 March 9, 2019 13:03
Question about the fvmatrix and Laplacian operator liuhuafei OpenFOAM Running, Solving & CFD 6 October 3, 2009 06:58
Operator declaration in Thermophysical library lena OpenFOAM Running, Solving & CFD 0 March 12, 2009 09:47
Material interfaces and the laplacian operator cliffoi OpenFOAM Running, Solving & CFD 8 November 8, 2006 08:57
Material interfaces using the laplacian operator cliffoi OpenFOAM 0 November 6, 2006 10:42
