May 30, 2018, 02:33 |
Mesh generated VOF fields (interFoam)
Kahlil Fredrick Cui
Rep Power: 8 |
Hello!
I would like to ask if anybody has an idea about how to make a mesh generated setFields (I don't know how to formally call this case so I'll just go with this). I want to make an fluid domain similar to the one in the picture attached, where separate domains are for the air and water. In setFields we usually do this using BoxToCell, but clearly it cannot be used for the one I/m trying to do. I have also heard of funkySetFields but I cannot imagine it working for me (but maybe I am wrong, I haven't actually tried). Thank you in advance! |
May 30, 2018, 03:20 |
Santiago Lopez Castano
Rep Power: 15 |
You mean like the interface being represented by a certain grid line?
May 30, 2018, 03:45 |
Kahlil Fredrick Cui
Rep Power: 8 |
Yeah. Maybe a better way of saying this is how can I create a non-box geometry for air-water phases in interFoam?
May 30, 2018, 03:57 |
Rep Power: 15 |
May 30, 2018, 03:59 |
Rep Power: 15 |
To create non box geometries has nothing to do with interfoam. Use pointwise or snappy to generate the geometry you need, and then run it using whatever OF solver you want.
May 30, 2018, 04:34 |
Kahlil Fredrick Cui
Rep Power: 8 |
No, I simply wish to implement interFoam where my initial fluid geometries are non-rectangular.
May 31, 2018, 03:29 |
For setFields, you can just make your box extend to outside your domain, so with a flat surface, you can still use a box. I guess this would work:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: dev | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object setFieldsDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // zWater = 700 defaultFieldValues ( volScalarFieldValue alpha.water 0 ); regions ( // Set cell values // (does zerogradient on boundaries) boxToCell { box (-999 -999 -999) (999 999 $zWater); fieldValues ( volScalarFieldValue alpha.water 1 ); } // Set patch values (using ==) boxToFace { box (-999 -999 -999) (999 999 $zWater); fieldValues ( volScalarFieldValue alpha.water 1 ); } ); // ************************************************************************* // |
May 31, 2018, 05:23 |
Kahlil Fredrick Cui
Rep Power: 8 |
Thank you very much! I'll give it a try. A friend also mentioned to me that I can manually set the water domain in 0/alpha.water by typing 1 in the face where I want water to be. I guess this is not the most elegant solution, but as long as my mesh is not super fine, it should be manageable.
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[ANSYS Meshing] Combine solid mesh generated in workbench mesh and fluid mesh in fluent meshing ? | RPjack | ANSYS Meshing & Geometry | 2 | August 27, 2015 09:33 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
