LES case diverges after 5 flow-through-time
Old   October 5, 2016, 04:19
Default LES case diverges after 5 flow-through-time
James Zh
mcshidada is on a distinguished road
Hi Foamers,
This is my first post
I'm doing Ma7 LES on rhoCentralFoam with kEqn model. The geometry is quite simple. The mapped inflow boundary condition is used as in the attached geometry. The back and forth patches are cyclic, while the top one is supersonicfreestream.
details of physical and numerical boundary conditions:
|  \\    /   O peration     | Version:  v3.0+                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       polyBoundaryMesh;
    location    "constant/polyMesh";
    object      boundary;
6
    INLET
        type            mappedPatch;
        inGroups        1(mappedPatch);
        nFaces          5355;
        startFace       5836184;
        sampleMode      nearestCell;
        sampleRegion    region0;
        samplePatch     none;
        offsetMode      uniform;
        offset          (0.06 0 0);
    SYM
        type            cyclic;
        inGroups        1(cyclic);
        nFaces          31195;
        startFace       5841539;
        matchTolerance  0.0006;
        transform       unknown;
        neighbourPatch  SYM2;
    SYM2
        type            cyclic;
        inGroups        1(cyclic);
        nFaces          31195;
        startFace       5872734;
        transform       unknown;
        neighbourPatch  SYM;
    WALL_D
        type            wall;
        inGroups        1(wall);
        nFaces          23121;
        startFace       5903929;
    OUTLET
        type            patch;
        nFaces          5355;
        startFace       5927050;
    FAROUT
        type            patch;
        nFaces          23121;
        startFace       5932405;
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      alphat;
dimensions      [1 -1 -1 0 0 0 0];
internalField   uniform 0;
boundaryField
    INLET
        type            calculated;
        value           uniform 0;
    FAROUT
        type            calculated;
        value           uniform 0;
    OUTLET
        type            calculated;
        value           uniform 0;
    SYM
        type            cyclic;
    SYM2
        type            cyclic;
    WALL_D
        type            zeroGradient;
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      k;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 4925.8;
boundaryField
    INLET
        type                mapped;
        value               uniform 4925.8;
        interpolationScheme cell;
        setAverage          true;
        average             4925.8;
    FAROUT
        type            zeroGradient;
    OUTLET
        type            zeroGradient;
    SYM
        type            cyclic;
    SYM2
        type            cyclic;
    WALL_D
        type            zeroGradient;
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      nut;
dimensions      [0 2 -1 0 0 0 0];
boundaryField
    INLET
        type            zeroGradient;
    FAROUT
        type            zeroGradient;
    OUTLET
        type            zeroGradient;
    SYM
        type            cyclic;
    SYM2
        type            cyclic;
    WALL_D
        type            zeroGradient;
FoamFile
    version     2.0;
    format      ascii;
    object      p;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 1341.28589;
boundaryField
    INLET
        type            fixedValue;
        value           uniform 1341.28589;
    FAROUT
        type            zeroGradient;
    OUTLET
        type            waveTransmissive;
        field           p;
        phi             phi;
        rho             rho;
        psi             thermo:psi;
        gamma           1.4;
        fieldInf        1341.28589;
        lInf            10;
    SYM
        type            cyclic;
    SYM2
        type            cyclic;
    WALL_D
        type            zeroGradient;
FoamFile
    version     2.0;
    format      ascii;
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 62.9;
boundaryField
    INLET
        type                fixedValue;
        value               uniform 62.9;
    FAROUT
        type            zeroGradient;
    OUTLET
        type            zeroGradient;
    SYM
        type            cyclic;
    SYM2
        type            cyclic;
    WALL_D
        type            zeroGradient;
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (1146.1 0 0);
boundaryField
    INLET
        type                mapped;
        value               uniform (1146.1 0 0);
        setAverage          false;
        average             (1146.1 0 0);
    FAROUT
        type            supersonicFreestream;
        pInf            1341.28589;
        TInf            62.9;
        UInf            (1146.1 0 0);
        gamma           1.4;
    OUTLET
        type            pressureInletOutletVelocity;
        inletValue      uniform (0 0 0);
        value           uniform (0 0 0);
    SYM
        type            cyclic;
    SYM2
        type            cyclic;
    WALL_D
        type            fixedValue;
Schemes and solution file
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
fluxScheme      Kurganov;
ddtSchemes
    default         backward;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(tauMC)      Gauss linear;
    div(phi,k)      Gauss Gamma 0.2;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         none;
    reconstruct(rho)    vanLeer;
    reconstruct(U)      vanLeerV;
    reconstruct(T)      vanLeer;
    interpolate(rhoU)   linear;
    interpolate(muEff)  linear;
    interpolate(tauMC)  linear;
    interpolate(rho)    linear;
snGradSchemes
    default         corrected;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    "(rho|rhoU|rhoE)"
        solver          diagonal;
    U
        solver          smoothSolver;
        smoother        GaussSeidel;
        nSweeps         2;
        tolerance       1e-07;
        relTol          0;
    e
        $U;
        tolerance       1e-7;
        relTol          0;
    k
        $U;
        tolerance       1e-7;
        relTol          0;
There are field contours of k, pressure, velocity magnitude and temperature in the attachment at time step just before it diverged.
I monitored the mass flow rate of all the patches and it seemed OK with the inlet, outlet and the freestream one. The mass flow rate of cyclic patch kept increasing up to around 0.01 of the oulet's, is it common? Maybe because the turbulent boundary layer is still developing, i am not sure.
The case has been running for about two days(around 5 flow-through-time), finally blow up...
Delta t is set to 1e-8 and the maxCo is less than 0.2 when it diverged.
I have stuck here for a week...
Any help will be appreciated.
Regards
James Zh
mcshidada is offline   Reply With Quote
Old   October 5, 2016, 06:36
James Zh
Any comment is welcomed
Old   July 17, 2018, 21:50
Ontario
chliu is on a distinguished road
I met the similar questions with rhoCentralFoam LES K equation, how did you solver you questions? I found little tutorial about rhocentralFoam LES. Thanks!
chliu is offline   Reply With Quote
high-speed, les, rhocentralfoam
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Same SimpleFOAM Case converges with openFOAM 2.1 but diverges with openFOAM 2.0.1 alsdia OpenFOAM Running, Solving & CFD 3 October 22, 2012 11:25
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
